JapCarForum
New HID kit arrived - Printable Version
+-- Forum: Cars, Cars, Cars! (https://www.japcarforum.com/forumdisplay.php?fid=11)
+--- Forum: Car Audio/Video/Electronics/Security (https://www.japcarforum.com/forumdisplay.php?fid=151)
+--- Thread: New HID kit arrived (/showthread.php?tid=2117)
Pages: 1 2
New HID kit arrived - steviewevie - 13-10-2017
Confusedhock: Wow, that's impressive ! :thumbup:
New HID kit arrived - parthiban - 13-10-2017
steviewevie Confusedhock: Wow, that's impressive ! :thumbup:
I'll to get a pic in the daytime to show more clearly, but if you look head on at the headlight, you can actually see that the bottom is dark, as no light is getting to it from the bulb.
I need to check this in the light also, but I don't think the bulb actually sits perfectly straight with the obscured part directly at the bottom in the IS200 headlamp, and that's why there is a very small amount of upward scatter still.
But yes I was impressed too that it actually works and highly recommend them :biggrin:
One other thing, the kits unfortunately cost more from HIDs4u than other suppliers, but if you stick in the promo code TOYOTA PRO or STRATHY you get a £40 discount :thumbup1:
New HID kit arrived - Davros - 13-10-2017
Looking good ! :thumbup1:
Do you happen to have a link for these ?
Davros Looking good ! :thumbup1:
Cheers mate, yep the ones I got are THESE
In the drop down for "bulb type" these are the ones "reflector 9006R" Smile
Cheers dude ! :biggrin:
New HID kit arrived - spikes - 13-10-2017
looking good:biggrin:
New HID kit arrived - Bandit - 13-10-2017
Not a bad cut off on them mate for a set of hid's, :thumbup1:
Might be worth popping into an MOT place, to see if they will line them up for you on the beam test, so you get the best out of them? :biggrin:
Yeah was thinking about doing that, I did stick some tape on the garage door for the level the halogens were at - the left one is bang on but as you can probably see the right is slightly higher than it was before.
I could have a go at levelling it myself, but it does make more sense to use a proper beam machine :thumbup:
I had mine done when i fitted them to mine mate, and they didn't charge me anything to do them,
but it did make quite a bit of difference to the beam after having them done? :thumbup1:
