240V A/C to 12V D/C converter - Printable Version +- JapCarForum (https://www.japcarforum.com) +-- Forum: General Discussions (https://www.japcarforum.com/forumdisplay.php?fid=3) +--- Forum: The JCF Lounge (https://www.japcarforum.com/forumdisplay.php?fid=17) +--- Thread: 240V A/C to 12V D/C converter (/showthread.php?tid=7386) Pages:
1
2
240V A/C to 12V D/C converter - toxo - 24-03-2019 You're right, they are really low current. 240V A/C to 12V D/C converter - jay_russell - 24-03-2019 this might be the way to go http://cgi.ebay.co.uk/POWER-INVERTER-CONVERTER-ADAPTER-AC-DC-240-V-12V-CAR-/220768712583?pt=UK_ConsumerElectronics_PowerAdaptors_SM&hash=item3366d73787 240V A/C to 12V D/C converter - jay_russell - 24-03-2019 he says to contact him if it's needing more than 5a 240V A/C to 12V D/C converter - Tango - 24-03-2019 jay_russell what about a battery charger on a switch. Tried that and it wouldn't move it. Thanks for all the comments guys, all very useful.:thumbup1: 240V A/C to 12V D/C converter - jimxms - 25-03-2019 I didn't make the connection (no pun!) until now, but I've got a PSU for sale that might suit you. Its this one here: http://www.scan.co.uk/products/520w-antec-high-current-gamer-80plus-bronze-135mm-quiet-fan-atx12v-23-eps12v-v291-psu?utm_source=google+shopping&utm_medium=google+shopping It's got a single 12v rail rated at 40A though technically it should be able to deliver more for short periods of time. Its brand new and I'm looking for about £30 if you think it'd suit. 240V A/C to 12V D/C converter - Tango - 25-03-2019 Quote:It's got a single 12v rail rated at 40A though technically it should be able to deliver more for short periods of time. Its brand new and I'm looking for about £30 if you think it'd suit. Thanks for your offer, but the spare PSU I have is an Antec 620W with a single 12V rail rated at 48A. It also has over current protection so it it should not be a risk hooking it up to the winch motor. However, I really need to use a multimeter to check what it draws as if it's over 50A then it'll not work anyway. 240V A/C to 12V D/C converter - toxo - 25-03-2019 You know what you're doing in terms of wiring it up? Like, yellow is 12v, red is 5v, blacks are all ground (but may be separate depending on the rail configuration) green is the wire to ground to turn PSU on etc. etc. I imagine to pull more than 10A through it you'll need to use multiple yellow wires as although the PSU is rated highly the wire is only good for a few amps. You might need to open up the PSU to identify which wires are which rails if it has multiple 12v rails (which by the sound of it it doesn't). 240V A/C to 12V D/C converter - Tango - 25-03-2019 Quote:I imagine to pull more than 10A through it you'll need to use multiple yellow wires as although the PSU is rated highly the wire is only good for a few amps. You might need to open up the PSU to identify which wires are which rails if it has multiple 12v rails (which by the sound of it it doesn't). After investigation it looks like the only practical solution is to leave it hooked up to the battery with my automatic battery charger permanently on. In theory the charger switches from charge to maintenance mode depending on the status of the battery, but I've yet to see it switch (which is what prompted this discussion). 240V A/C to 12V D/C converter - toxo - 25-03-2019 To be honest it still would've been advisable to leave a 12v leisure battery in series with the device anyway. Current smoothing and all that
