JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Viper VX480 Wire colours????
Pages (13): Previous 1 … 9 10 11 12 13 Next
Jimbob-T-Lex
Moderator
1,138
07-01-2019, 07:36 PM
oh right mate im with you ok ill link up 2moz then thx mate!
Jimbob-T-Lex
07-01-2019, 07:36 PM #101
Jimbob-T-Lex
Moderator
1,138
07-01-2019, 07:39 PM
What sort of amps am i looking at mate for the relays
Jimbob-T-Lex
07-01-2019, 07:39 PM #102
07-01-2019, 07:52 PM
Average I think is 20amps
07-01-2019, 07:52 PM #103
Jimbob-T-Lex
Moderator
1,138
07-01-2019, 08:00 PM
**** relays are like a fiver each where else ppl get them lol not maplin i hope lol
Jimbob-T-Lex
07-01-2019, 08:00 PM #104
07-01-2019, 08:02 PM
any car relay will do mate, get yourself to the scrappy and raiding cars. (as long as you get normal relays and not the indicator ones that turn on and off themselves)
07-01-2019, 08:02 PM #105
07-01-2019, 08:15 PM
eBay is a great place I got 10 relays and harnesses for 20 quid I think it was...
07-01-2019, 08:15 PM #106
Jimbob-T-Lex
Moderator
1,138
07-01-2019, 08:25 PM
relays on there way so ill do next weekend then cheers agaim all for your help!
Jimbob-T-Lex
07-01-2019, 08:25 PM #107
08-01-2019, 10:30 AM
Sparkystav no, the output from your module will be 2 12v signals which would go to the window motors.
instead put them to 2 relays each so the relays put the 12v to all 4 windows. the unit should be able to power 2 relays easily.
That probably won't work, if the window closer module is the type that you connect directly to the window motors. If it is, it stop trying to close the windows when it sees the resistance building, when the motor is trying to push the window through the top of the door. That's also how they stop trying to close the window if someone's arm etc is trapped in it. It'll never see resistance if it's just powering 2 relays, so it'll never stop trying to close the windows.
08-01-2019, 10:30 AM #108
08-01-2019, 10:31 AM
toxo That probably won't work, if the window closer module is the type that you connect directly to the window motors. If it is, it stop trying to close the windows when it sees the resistance building, when the motor is trying to push the window through the top of the door. That's also how they stop trying to close the window if someone's arm etc is trapped in it. It'll never see resistance if it's just powering 2 relays, so it'll never stop trying to close the windows.
very good point mate!
08-01-2019, 10:31 AM #109
Jimbob-T-Lex
Moderator
1,138
08-01-2019, 05:37 PM
any1 know the wire colours for the indicators lol its peeing it down outside wanna be quick doing it lol
Jimbob-T-Lex
08-01-2019, 05:37 PM #110
Views 3,818
22-07-2022, 05:50 AM
