JapCarForum Cars, Cars, Cars! Project Cars another is200 project
Pages (37): Previous 110 11 12 13 1437 Next
ZAIS200
29-04-2021, 11:09 AM
yep thanks John, will do
ZAIS200
29-04-2021, 11:09 AM #111
john wan
29-04-2021, 05:30 PM
[Image: 20130610_194428_zps831c87ac.jpg]
So with me trying the actuator arm fitted on sat an it having way more boost I thought id try the actuator off my t25 I have sat around even found out that saab 900 turbos have a adjustable actuators so I had to make up a plate to fit it as the plate I have is stamped onto my t28 actuator
Edited 10-06-2013, 09:17 PM by john wan.
john wan
29-04-2021, 05:30 PM #112
29-04-2021, 05:46 PM
Nice job!
29-04-2021, 05:46 PM #113
Nice job!
john wan
29-04-2021, 05:55 PM
Looks poo for now but just wanna see if it works then ill do it properly
john wan
29-04-2021, 05:55 PM #114
john wan
01-05-2021, 03:50 PM
So pootleing home tonight fro. Work an me **** management light came on throwing up p04020 or 420 catalist bank one below efficiency so from what av found me cats blocking so kinda thought this might happen with me running rich so anyone suggest some good cat shmpoo? Wanna try that first
john wan
01-05-2021, 03:50 PM #115
john wan
03-05-2021, 04:02 PM
So put some cleaner in lastnight an the light comes up again an running a bit lumpy still coming up to rich
So ive turned down the fpr hopefully thatl cure it cause once I fitted the slightly bigger injectors it was reading rinch priety much all the time . I adjusted the actuator in a bit an get boost some times to 0, 5 0, 6 but allways fades off an drops to 0, 3ish an get a bit of a squeal as I floor it so think got a boost leak somewhere or me engine is saying aaaaahhhhhh bbbbbbooooossssstttt still makes me smile thinking of droping the old actuator back on an buying a didifferent boost controller dont think the one I have drops down low enough
john wan
03-05-2021, 04:02 PM #116
john wan
04-05-2021, 04:56 PM
So decided to remove the injectors today an go back to originals the greens are making me run to rich think my actuator is leaking to
john wan
04-05-2021, 04:56 PM #117
04-05-2021, 05:02 PM
Hope it fixes it mate.
04-05-2021, 05:02 PM #118
john wan
04-05-2021, 05:28 PM
Me to.mate got some judddddery jerky tings goin on
john wan
04-05-2021, 05:28 PM #119
john wan
05-05-2021, 09:50 AM
Right been out for a pootle an car seems fine all guages working as they should do ie afr dances nice in optimal an rich when ah give it some beans so as I was coming up to yhe garage the ecu light came on saying cat below efficiency so think ive messed up the cat having it run to rich with the other injectors so these will be up for sale soon would be ideal for a higher boost car
john wan
05-05-2021, 09:50 AM #120
 3 Guest(s)
 3 Guest(s)
Views 15,060
Views 4,114
Views 5,047
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 178,975
Views 23,355
Views 48,867
Views 145,507
Views 1,368
Views 3,964
Views 6,891
