Pages (132): Previous 1 … 11 12 13 14 15 … 132 Next
14-08-2017, 10:55 AM
Bandit Have you got a new set of head bolts/studs mate? usually reccomended when removing/replacing the head? Not sure on the IS though if its one of those things that are usually done? Smile
No, but I will ask, thanks. Steve hasn't mentioned those to me so I'm assuming he doesn't think that's needed. I'll check though.
Quote:Looking forward to seeing it all on your motor now mate and hopefully the pistons etc will be ok to use :thumbup:
Thanks mate :biggrin:
14-08-2017, 10:55 AM #121
14-08-2017, 10:57 AM
Must admit Steve I dont like reading this thread but I cant help myself.
Its just because the more I read it the more I want to do something similar.
I would like to go the way Stav has went but would also like to see yours when finished.
Then you never know what's going to happen next :ohmy:
Good luck with it mate
14-08-2017, 10:57 AM #122
russelllinn
14-08-2017, 11:01 AM
Worth checking, I've read that it might as well be done at the same time, then you know they are in top nick and got the strength behind them, you can stick with OEM bolts or ARP are always a good bet, I would go with whichever is cheaper as they'll both be strong enough.
Is the HG a thicker one for lowering the compression or are you sticking with the standard compression ratios / using the GTE pistons?
russelllinn
14-08-2017, 11:01 AM #123
14-08-2017, 11:10 AM
Moley Must admit Steve I dont like reading this thread
I wondered what you were going to say there, if I had made some sort of horrendous mistake or something :crying:
Quote:Its just because the more I read it the more I want to do something similar.
Ah that's ok then :laugh:
Quote:I would like to go the way Stav has went but would also like to see yours when finished.
Personally I'd prefer to keep the original engine rather than transplant something else in. But all credit to those who do go down the engine swap route, it would be boring if we all liked the same thing ! :biggrin:
russelllinn Worth checking, I've read that it might as well be done at the same time, then you know they are in top nick and got the strength behind them, you can stick with OEM bolts or ARP are always a good bet, I would go with whichever is cheaper as they'll both be strong enough.
I just asked and basically they say the Lexus bolts tend to be pretty good but it depends on the condition of them when the head comes off, i.e. sometimes they swap them and sometimes they don't. I wonder whether the bolts might as well be swapped just to be on the safe side.
Quote:Is the HG a thicker one for lowering the compression or are you sticking with the standard compression ratios / using the GTE pistons?
Nope, just an OEM one, should be using the GTE pistons with their different compression ratios.
Latest news on the GTE engine is that although it did look like the head gasket had gone, it now looks more likely that it was just condensation from the car being sat around not having been used for a while.
14-08-2017, 11:10 AM #124
russelllinn
14-08-2017, 11:43 AM
steviewevie I wonder whether the bolts might as well be swapped just to be on the safe side.
Maybe worth while then your safe in the knowledge!!
You have taken every other precaution in your build making sure it's right first time why stop here :wink:
Good news with the GTE engine then bud, i expect you were anxious to find out and now a bit relieved Confusedmoke:
russelllinn
14-08-2017, 11:43 AM #125
14-08-2017, 11:56 AM
Totally out of curiosity and nothing else, are you going to be dressing the engine up in any way while it's in bits like polishing it up?
All looks like it's coming along nicely though, your house must look like a parts store with all the bits floating around :lol:
14-08-2017, 11:56 AM #126
14-08-2017, 04:20 PM
parthiban Totally out of curiosity and nothing else, are you going to be dressing the engine up in any way while it's in bits like polishing it up?
No. It would be a very nice idea, but that would probably take a fair bit of time in itself to do properly. And given that my Lex is my daily driver, I don't want the car to be off the road for any longer than necessary. I guess I'll just have to try and clean it up myself as best I can !
Quote:All looks like it's coming along nicely though, your house must look like a parts store with all the bits floating around :lol:
Thanks, yes my kitchen does look somewhat like a Japanese car parts warehouse :laugh:
14-08-2017, 04:20 PM #127
buddy8
Unregistered
14-08-2017, 06:21 PM
hi there sorry to butt in but dont you think your turbos a bit on the small side,
rember its a 6cly not a 4cly,
buddy8
14-08-2017, 06:21 PM #128
14-08-2017, 06:32 PM
buddy8 hi there sorry to butt in but dont you think your turbos a bit on the small side,
I may be wrong but its still a 2L, still the same displacement, still the same amount of exhaust gases?
so i dont see a problem?
14-08-2017, 06:32 PM #129
14-08-2017, 06:38 PM
My 2.5ltr 6cyl only runs a turbo about the same size and that seems fine to me?
14-08-2017, 06:38 PM #130
Views 15,411
Views 4,215
Views 5,166
04-04-2025, 09:14 PM
Last Post by DannyStock
Views 183,003
Views 23,893
Views 49,657
Views 148,358
Views 1,404
Views 4,067
Views 7,014
