JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Dimis the parts finder
Pages (243): Previous 1136 137 138 139 140243 Next
Fry-Up
06-04-2019, 08:15 PM
dodgydave Well the posty delivered a parcel today.
So if anyone's got a copy of the instructions they could scan for me I would be much obliged and I am going to need some advice on how best to fit these without the kit; I know a lot of people have done it.
i've got instructions but no scanner, but I can post, however I didn't use my kit, just the screws for the arches, theres 2 screws for the top of each end, and 2 for the bottom
make sure the car is clean and free from grease along where the side skirts will sit.
(I actually taped the skirts ready a few days before fitting so I know it was well attached to the skirts beforehand)
I stuck vhb tape all along the top edge of each skirt, and screwed just the bottom screw on each end, this allows you to rotate the top edge of the skirt away from the body work, very easy to position it before removing the backing from the vhb tape,
I supported the skirt in the middle when I removed the backing tape (so it didn't bow) and held it for as long as I had patience to just sit on the driveway (about 20 mins), then I did the other 2 screws and tightened them all
good weather for a couple of weeks helped too
on one end, i'm not sure which, the top screws don't line up, theres a metal clip with the fitting kit which sits in that does line up, Ormi mentioned in a recent thread that he'd made a couple for someone but I can't find it
Fry-Up
06-04-2019, 08:15 PM #1,371
Rolex
07-04-2019, 03:44 AM
Lexuspat Never seen that TRD lip before
But maybe someone on here has
Looks like a Vizage Splitter
Rolex
07-04-2019, 03:44 AM #1,372
07-04-2019, 07:27 AM
Fry-Up i've got instructions but no scanner, but I can post, however I didn't use my kit, just the screws for the arches, theres 2 screws for the top of each end, and 2 for the bottom
Ormi made up the brackets for my side skirts - the post is here... Perfect snug fit too Smile
07-04-2019, 07:27 AM #1,373
dodgydave
07-04-2019, 09:30 AM
Thanks everyone for your help and comments and Fry-up don't worry about the instructions. With all the comments and various threads on the fitting of these I think I've got enough info. Also if the fitting instructions are the same as the ones I've got with my front lip then they're about as much use as a chocolate fire guard anyway.
The one thing I'm still not sure of is whether you do anything with the bit that goes underneath the sill. Do you stick this with tape to the underside of the sill or not?
dodgydave
07-04-2019, 09:30 AM #1,374
07-04-2019, 09:44 AM
dodgydave Thanks everyone for your help and comments and Fry-up don't worry about the instructions. With all the comments and various threads on the fitting of these I think I've got enough info. Also if the fitting instructions are the same as the ones I've got with my front lip then they're about as much use as a chocolate fire guard anyway.
Don't have to, no. Mine aren't fixed in any way underneath, neither are Ormi's...
07-04-2019, 09:44 AM #1,375
Fry-Up
07-04-2019, 10:40 AM
mine aren't either, but they don't sit against the sill underneath, the fitting kit includes a few plastic spacers but for mt thats a faff, as with the others who haven't attached underneath, vhb along the top edge and the screws on each end should be more than enough
when you come to actually fit them you'll see how easy it is
Fry-Up
07-04-2019, 10:40 AM #1,376
bash6673
18-04-2019, 04:58 AM
Black headlights with halos.
http://cgi.ebay.co.uk/Lexus-IS200-Headla...3a668accb8
bash6673
18-04-2019, 04:58 AM #1,377
18-04-2019, 07:47 AM
Lexus Is200 Tte Eibach Lowering Springs
http://cgi.ebay.co.uk/Lexus-Is200-Tte-Ei...2c5d05a0f4
HKS SUPER DRAGGER BACK BOX - ALTEZZA SXE10
http://cgi.ebay.co.uk/HKS-SUPER-DRAGGER-...35b279535c
EXEDY PADDLE TYPE CLUTCH DISC LEXUS IS200 SXE10 3S-GE
http://cgi.ebay.co.uk/EXEDY-PADDLE-TYPE-...3a65f79d69
lexus is200 / Toyota Altezza - sat nav screen -
http://cgi.ebay.co.uk/lexus-is200-Toyota...3a666b6622
toyota altezza is200 trd front bumper & grill package
http://cgi.ebay.co.uk/toyota-altezza-is2...2563b6d5b4
Toyota, Altezza, is200, Lexus, ganadoor mirrors, Jdm
http://www.ebay.com.au/itm/Toyota-Altezz...3a6659c5f1
Toyota, Altezza, is200, Lexus, sway bars japanese, jdm
http://www.ebay.com.au/itm/Toyota-Altezz...3a6659ca83
18-04-2019, 07:47 AM #1,378
Fry-Up
23-04-2019, 03:01 PM
TTE front bumper from the same seller
Fry-Up
23-04-2019, 03:01 PM #1,380
 6 Guest(s)
 6 Guest(s)
Views 1,044
03-09-2022, 04:53 PM
Views 931
19-08-2020, 09:50 AM
Last Post by S
Views 680
22-03-2020, 12:26 PM
Views 2,010
14-12-2019, 02:47 PM
Views 1,135
14-05-2019, 05:51 AM
Last Post by reganlives
Views 720
30-03-2019, 05:40 AM
Last Post by TommyH
Replies 32
Views 3,477
20-11-2018, 08:34 PM
Last Post by Steveboiboi
Views 1,323
06-10-2018, 01:46 PM
Last Post by purplewitch
Views 931
31-08-2018, 09:19 AM
Last Post by edeath
Views 395
26-08-2018, 06:27 PM
Last Post by ibby
