Pages (76): Previous 112 13 14 15 1676 Next
20-09-2017, 03:04 PM
Well that didn't go too well. I must have really ****** somebody off in a previous life.
Anyone want to buy an MR2?
Edited 01-11-2009, 07:12 PM by Bandit.
20-09-2017, 03:04 PM #131
20-09-2017, 03:19 PM
Whats happened mate?
20-09-2017, 03:19 PM #132
20-09-2017, 03:42 PM
Oh no, what's up ? :confused1:
20-09-2017, 03:42 PM #133
20-09-2017, 03:59 PM
I think the master cylinder is shot, brakes won't bleed as a result so the car is undriveable and I've had to leave it at my friends unit. I have had 4 people look at the brakes now and all of them be unable to diagnose the problem.
Also found out while it was up on the ramps that one of my CV joints is bust and I need 2 new front tyres, probably a wheel alignment too.
20-09-2017, 03:59 PM #134
20-09-2017, 05:56 PM
That's a bummer mate. Is the master cylinder mega-expensive to replace ? Or can you get one without too much trouble from a breaker's perhaps ?
How about the CV joint, is that a difficult/expensive one ?
20-09-2017, 05:56 PM #135
21-09-2017, 10:52 AM
Slightly better news today, apparently they took the car off the ramps this morning and the brakes are working (??!). They're not great but they'll pass an MOT and that's good cause it means I can drive the car again and don't need to buy a new master cylinder this month (£250). I can't find any pattern master cylinders, brakes international don't stock them and blueprint don't make one either. I'm still going to replace it though, as the brakes on this car have always been terrible and have never bled reliably so it must be a bit buggered.
Also discovered that:
a) the sliders are buggered, and they're part of the carrier so thats new carriers both sides (one of them is BENT?!?! WTF)
b) one of the bolts that mounts the carrier is knackered (only about 1/3rd thread left, suspect thread in carrier is shot)
c) 2 of the caliper bolts are knackered too!
So they all need replacing. The sliders are 1 piece with the carrier so 2 x new carriers (at least I can paint them then), 1 x new carrier bolt, 2 x new slider bolts and 1 x new master cylinder. Fortunately the carriers & bolts can all be done on a jack, so I don't need to waste yet more of my friend Matt's time with the car up on ramps. He does have a very nifty pressure bleeder for clutches & brakes though, which attaches to an airline and sucks all the fluid through.
Anyway, here are some pictures. This is what I had at the start of the weekend:
[Image: SDC10674.JPG]
Before:
[Image: SDC10675.JPG]
Caliper + disc off, braided hose fitted:
[Image: SDC10676.JPG]
The Goodridge fittings weren't quite right, had to file out one of the holes:
[Image: SDC10677.JPG]
Old caliper:
[Image: SDC10678.JPG]
New and shiny!
[Image: SDC10679.JPG]
These are the pads off the side that was really buggered, the top one has no friction material at all and I had been braking with the pad mount :o
[Image: SDC10680.JPG]
Fronts only got hoses, but here's a pic featuring my ridiculous wheel spacers:
[Image: SDC10681.JPG]
steviewevie Is the master cylinder mega-expensive to replace ? Or can you get one without too much trouble from a breaker's perhaps ?
As per above, £250 inc VAT with my discount (normally £290 inc VAT). I won't put a second hand cylinder on my car, they stopped making the cars 9 years ago and no rubber seals are that good! Plus the later the cars the more ABS seems to be the norm, so I'd be getting an older cylinder. AFAIK post '97 cars had ABS as standard. Not worth it with something as important as brakes. Only other options seem to be upgraded cylinders which is pointless as I don't intend to upgrade the friction components.
CV joints are an issue in MR2s (what isn't?) when you go above 300bhp. As a result there are uprated replacements available from ATS and CRW, both of which are around £200 - £250 per side.
Edited 02-11-2009, 03:49 PM by toxo.
21-09-2017, 10:52 AM #136
Before:
Old caliper:
New and shiny!
21-09-2017, 11:04 AM
love those spacers haha Big Grin
21-09-2017, 11:04 AM #137
21-09-2017, 11:13 AM
dan_harris love those spacers haha Big Grin
Yeah they are a bit epic Big Grin Can't remember whether they're 20mm or 25mm but as you can see they completely engulf the studs!
21-09-2017, 11:13 AM #138
21-09-2017, 12:01 PM
And to think I've got all this coming when the Boxter goes and gets replaced with an MR2 GTS.
21-09-2017, 12:01 PM #139
21-09-2017, 12:03 PM
You can buy mine if you like. Well looked after Big Grin
21-09-2017, 12:03 PM #140
Views 3,259
Views 3,761
Views 13,441
Views 6,609
Views 34,192
Replies 79
Views 10,854
02-09-2024, 04:19 PM
Views 4,866
Views 10,114
Views 1,558
Views 1,867
