JapCarForum Cars, Cars, Cars! Project Cars Lexus 3S200 GTE Build
Pages (26): Previous 115 16 17 18 1926 Next
supratruck
25-11-2017, 11:49 AM
Agree with Toxo when you do a build fit new heart , lungs and kidney ie OIL PUMP , WATER PUMP , TIMING BELT and THERMOSTAT before you buy any air freshener.s to go with the rest , Shame i could not do the clutch could really do with the cash
supratruck
25-11-2017, 11:49 AM #161
25-11-2017, 01:30 PM
Yea I wish you were doing it also, it started to slip even off boost, and with a leeking water pump it wouldn't have made it to you. Why can't you be based nearer to me, you would have ALL the work.
25-11-2017, 01:30 PM #162
russelllinn
25-11-2017, 07:05 PM
Good to hear that its all getting done you'll have a smooth running motor there buddy :thumbup1:
russelllinn
25-11-2017, 07:05 PM #163
26-11-2017, 08:54 AM
Car was 100% sorted by SPC, these are little jobs that needed attention. It runs smoothly and quickly:laugh:
26-11-2017, 08:54 AM #164
26-11-2017, 02:19 PM
Great to hear all's going well with the motor mate, 300+ is not good in the snow/ice :Chair: good fun but can get a bit hairy when your drifting in a straight line :w00t:
Still looking forward to being taken for a blast in it, now its sorted and running the power you wanted originally :thumbup1:
26-11-2017, 02:19 PM #165
26-11-2017, 02:37 PM
Snow has stopped work on the car - mechanic can't get to work, the apprentice can but isn't touching my car:Shooting::Shooting:!!
Doesn't matter because their garage is at the bottom of a hill, only way out is up the hill that isn't gritted and has deep compacted snow, so the Lex wouldn't get out anyway, so the car is sitting in the warm garage protected from the cold:laugh:
26-11-2017, 02:37 PM #166
26-11-2017, 05:11 PM
just been reading all of it now. glad to hear the car is running good mate.
26-11-2017, 05:11 PM #167
28-11-2017, 08:02 AM
OK car back on the road, and everything works perfect, even a slight and I mean slight misfire when 1st moving off when engine is cold is gone, all down to the new timing belt, which shows cheap belts ARE NOT ANY GOOD.
With me there is always a BUT though............ Here goes,
The water temp is just not getting hot whilst driving, on idle it gets to 70c no problem but as soon as the car is moving it falls to nothing. Thermostat is new and works properly, no leaks from the housing etc.
How can I get the coolant up to operating temperature???????
Edited 09-01-2010, 11:49 AM by FirebirdPhil.
28-11-2017, 08:02 AM #168
28-11-2017, 08:09 AM
2tongues OK car back on the road, and everything works perfect, even a slight and I mean slight misfire when 1st moving off when engine is cold is gone, all down to the new timing belt, which shows cheap belts ARE NOT ANY GOOD.
Don't know about the coolant, sounds like something is still not working properly there.
But regarding the timing belt, surely that's not an issue about cheap belts, more an issue about the previous belt not having been installed properly ?
28-11-2017, 08:09 AM #169
28-11-2017, 08:13 AM
It is a well known fact with 3SGTE's that cheap belts are not worth the saving. SPC have seen supposedly good belts throw timing off and when replaced with OEM one all is fine again. They warned me that when doing the water pump to ensure an OEM one was used highlighted by their previous experience.
28-11-2017, 08:13 AM #170
Views 175,399
Views 47,709
Views 140,982
Views 3,259
Views 3,763
Views 13,451
Views 6,610
Replies 76
Views 7,881
29-09-2024, 07:13 AM
Last Post by RichS11
Views 34,196
Views 4,866
