JapCarForum Cars, Cars, Cars! Project Cars My IS300 story so far....
Pages (28): Previous 115 16 17 18 1928 Next
10-06-2019, 08:18 PM
Niice, can't wait to see this all up and running Smile
Is THIS the magnaflow part you got?
I've been looking at getting one myself as my exhaust guy told me the main cat is the most restrictive part of the OEM system.
10-06-2019, 08:18 PM #161
11-06-2019, 05:21 AM
Dark Samurai Looking good Jim!
How much of an increase would the meth kit bring?
On its own, none really. The main benefit of running meth is that is pretty much reduces engine knock / pre-ignition to zero, reducing the chances of killing the engine.
However, this also means that you can run more aggressive timings or increase the boost. Which will be handy when I put on my new pulley Wink
Oh and it also steam cleans the engine Wink
sprinter2012 Niice, can't wait to see this all up and running Smile
Nah thats a whole system...and bloomin expensive by the look of it too :o
Here's the one I purchased: http://cgi.ebay.co.uk/2-5-MagnaFlow-200-...3cb8c4681e
I think if you're planning to weld it to the OEM downpipe you might want the 2.25" one though. I can check measurements of my OEM pipe if you are thinking of buying one.
11-06-2019, 05:21 AM #162
11-06-2019, 05:32 AM
jimxms Oh and it also steam cleans the engine Wink
How do you you get way with putting water in your engine and not killing it? Is it just such a small amount that it doesn't matter? I always thought the 1000 times expansion in volume from water to steam was a recipe for bent...everything. :lol:
jimxms I think if you're planning to weld it to the OEM downpipe you might want the 2.25" one though. I can check measurements of my OEM pipe if you are thinking of buying one.
Aah good I'm glad to see I found the same seller as you used, and yes that was my intention. Just waiting on a couple of quotes but I'm almost certain that buying one of those and just getting them to weld it in (as opposed to them supplying one too) will be the cheapest option Smile
And if you could give your pipe a quick measure that would be most useful Blush
11-06-2019, 05:32 AM #163
11-06-2019, 05:36 AM
I would think something in the region of £60 would be about right.
I paid £100 to have my one welded in, but that also included fitting of the new downpipe along with new gaskets. I also think it was a bit of a pig job as the piping on my Turboeast downpipe had to be flared from 2.36" to 2.5" in order for it to weld up cleanly.
11-06-2019, 05:36 AM #164
11-06-2019, 05:40 AM
That sounds pretty reasonable to me, if thats the case I'll probably be ordering one next week Smile
Nice to see Turboeast use nice round figures for their pipes...
11-06-2019, 05:40 AM #165
11-06-2019, 07:11 AM
Glad you like the downpipe and cat on there. I was interested in buying when you were thinking of selling! So will watch Sprinter carefully too, and see what he gets up to before deciding what to do myself. Still deciding whether to splash out on a manifold or just use a de-catted stock one.
sprinter2012 I've been looking at getting one myself as my exhaust guy told me the main cat is the most restrictive part of the OEM system.
And the cats in the manifold are the second most restrictive part, I'd say!
11-06-2019, 07:11 AM #166
11-06-2019, 03:45 PM
sprinter2012 How do you you get way with putting water in your engine and not killing it? Is it just such a small amount that it doesn't matter? I always thought the 1000 times expansion in volume from water to steam was a recipe for bent...everything. :lol:
The water's atomized by the time it gets anywhere important so it's not that big of a deal. And it's such a small amount anyway that it wouldn't even make 1PSI of difference when it does expand from the state change.
All forced induction cars should be water/meth injected IMO, it's the single simplest thing you can do to preserve your engine!
11-06-2019, 03:45 PM #167
12-06-2019, 05:12 PM
toxo The water's atomized by the time it gets anywhere important so it's not that big of a deal. And it's such a small amount anyway that it wouldn't even make 1PSI of difference when it does expand from the state change.
^ what he said. Before I fitted the injector to my intake I had it pointing at my windscreen so I could see when it activated during driving. It sprays such a fine mist that I imagine it would evaporate well before bring compressed by pistons.
Anyway, I finished installing it all on Saturday. I needed to purchase a longer length of nylon tubing to run the entire length of the car and across the engine bay. I think the install was quite tidy in the end. The only bit that I could have probably done better was the routing through the firewall.
[Image: l_boost.jpg]
[Image: l_boost2.jpg]
12-06-2019, 05:12 PM #168
12-06-2019, 05:17 PM
Take me for a drive!
12-06-2019, 05:17 PM #169
Phil01
14-06-2019, 05:25 AM
I fitted water injection to a 2.8litre Ford Capri 30yrs ago, well infact it was steam injection,
I had a water tank that was plumbed into the inlet manifold, the water has heated and boiled by (dont laugh) a 55watt H1 halogen bulb, as the water vapour was entering the engine you could defo feel an increase in bhp due to greater volumetric efficiency, very dense damp air
Edited 26-07-2011, 09:13 AM by Phil01.
Phil01
14-06-2019, 05:25 AM #170
Views 4,304
12-02-2024, 11:26 AM
Replies 32
Views 5,498
12-02-2024, 07:29 AM
Replies 53
Views 12,198
18-10-2022, 06:53 AM
Replies 18
Views 2,698
03-04-2022, 09:02 PM
Replies 48
Views 6,206
07-10-2021, 08:55 AM
Last Post by Stoney
Views 1,671
28-08-2021, 08:34 AM
Last Post by iceman
Replies 565
Views 57,686
22-04-2021, 12:04 PM
Last Post by purplewitch
Replies 86
Views 9,590
21-02-2021, 08:54 AM
Last Post by paddywak
Views 1,924
05-12-2019, 07:18 AM
Last Post by IanS200
Replies 41
Views 6,158
18-12-2018, 02:12 PM
Last Post by Dark Samurai
