JapCarForum General Discussions The JCF Lounge Av guys please come in here.
reganlives
20-02-2021, 11:23 AM
Go for CAT6 instead then if you were to upgrade to a gigabit connection within your house ie, gb switch etc you'd be covered. CAT6 cabling is also more reliable.
I work in IT Wink
reganlives
20-02-2021, 11:23 AM #11
I work in IT Wink
20-02-2021, 12:22 PM
If you work in IT then you should know CAT6 offers no functional benefits over 5e. The differences over 5e are that it's more resistant to interference from power, and that you have to be certified to install it, which is where the main advantages over 5e come from (standardised bend radius, only using approved patch panels etc). I doubt the OP is a certified CAT6 installer so most of the benefit is lost.
CAT6e is dramatically improved over both CAT5e and 6, and is required for reliable operation at 10gbe.
20-02-2021, 12:22 PM #12
20-02-2021, 12:31 PM
Griff'ism 101
20-02-2021, 12:31 PM #13
Griff'ism 101
Mikey
20-02-2021, 01:09 PM
ok no idea about that last bit of info but as Toxo puts it i need a certified installer so forget that way - DIY ftw
Dan just googled that and came up with this what you been up to lol
Mikey
20-02-2021, 01:09 PM #14
reganlives
20-02-2021, 01:16 PM
toxo If you work in IT then you should know CAT6 offers no functional benefits over 5e. The differences over 5e are that it's more resistant to interference from power, and that you have to be certified to install it, which is where the main advantages over 5e come from (standardised bend radius, only using approved patch panels etc). I doubt the OP is a certified CAT6 installer so most of the benefit is lost.
Toxo, I was mainly pointing out the fact that it would provide flexibility if he were to go for a gigabit network, and as you stated above, its more resistant to interference. As for needing to be certified to install it, never heard that before. On a cost basis however, CAT5e should be ok.
reganlives
20-02-2021, 01:16 PM #15
20-02-2021, 01:22 PM
Gigabit works just fine over CAT5e, always has done. From wikipedia:
Quote:Each 1000BASE-T network segment can be a maximum length of 100 meters (328 feet), and must use Category 5 cable or better (including Cat 5e and Cat 6).
AFAIK 1000BASE-T actually predates CAT6. I did make a mistake in my earlier post though, when I said CAT6e I meant CAT6a :o
Edited 03-04-2013, 05:08 PM by toxo.
20-02-2021, 01:22 PM #16
Mikey
27-04-2021, 08:39 AM
ok guys this is what i was thinking when i orderd the cable dose it look ok to star doing or would there be an better way of doing it
[Image: networksetup.jpg]
Mikey
27-04-2021, 08:39 AM #17
Mikey
27-04-2021, 08:43 AM
come to think of it now i could of run coaxial cable from the incoming signal straight to the out house then connect that to a wireless router like the way it is connected in the house, but ive got 50mtr of cat5e now so might aswell use it
Mikey
27-04-2021, 08:43 AM #18
27-04-2021, 08:44 AM
Mikey come to think of it now i could of run coaxial cable from the incoming signal straight to the out house then connect that to a wireless router like the way it is connected in the house, but ive got 50mtr of cat5e now so might aswell use it
You can only have one ADSL/Broadband router per phone line, so if you did that you'd have to have got rid of the one in the house. You can't split them like you can a telephone.
27-04-2021, 08:44 AM #19
Mikey
27-04-2021, 08:52 AM
in a easier way which way would you wire this in
[Image: networksetup2.jpg]
Mikey
27-04-2021, 08:52 AM #20
Views 510
14-06-2021, 06:10 PM
Replies 74
Views 9,704
19-09-2019, 07:24 AM
Last Post by johnyboy1976
Replies 23
Views 3,216
11-02-2019, 01:43 PM
Views 1,784
22-08-2018, 05:49 PM
Last Post by Chris
Views 2,406
01-07-2018, 01:25 PM
Views 626
05-06-2018, 06:46 AM
Replies 107
Views 9,619
30-03-2018, 06:28 PM
Last Post by John G
Replies 22
Views 2,418
23-03-2018, 07:43 PM
