JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Timing belt help please!
James S
15-05-2021, 10:48 AM
The garage I have taken mine too have rung me to say they can't get the crank pulley off! Have had to order a new pulley from Lexus! Bad times!
James S
15-05-2021, 10:48 AM #11
15-05-2021, 10:56 AM
Gutted! How they getting it off then?
15-05-2021, 10:56 AM #12
15-05-2021, 12:34 PM
hmmm if they cant get it off, why did they order a new one? how are they going to replace it if the old one wont budge, or are they cutting the old one off?
think they need a longer breaker bar. we had to use a 7 foot long piece of scaffolding on mine so that shows how much leverage can be needed.
15-05-2021, 12:34 PM #13
James S
15-05-2021, 05:39 PM
They have said they have had the radiator and a/c panel out and used all sorts to try get it off including heat!
I can only imagine that they will cut it off. Genuine part was only 50quid. So not too bad.
James S
15-05-2021, 05:39 PM #14
reganlives
16-05-2021, 11:12 AM
They're not tightening it instead of loosening it by any chance are they? Is the threading reversed on it?
reganlives
16-05-2021, 11:12 AM #15
16-05-2021, 11:38 AM
Nah it's def a normal thread. I had mine off the other night to change the pulley.
16-05-2021, 11:38 AM #16
16-05-2021, 12:00 PM
would heating the bolt not make it harder to get out? as it would expand in its hole
16-05-2021, 12:00 PM #17
mark3
16-05-2021, 01:13 PM
Maybe they mean what they say and actually cant get the pulley off (rather than cant get the bolt undone/out) as getting pulleys off is sometimes a right pain too, and if i recall the holes in a 2JZ front pulley aren't threaded so that don't help either.
mark3
16-05-2021, 01:13 PM #18
mark3
16-05-2021, 01:15 PM
Oh and using the breaker bar and starter method is excellent way of undoing crank pulley/damper bolts but you must have facilities to do them back up to the correct torque or the bolt will be for ever coming loose.
mark3
16-05-2021, 01:15 PM #19
16-05-2021, 01:18 PM
Do not ever use heat on the crank pulley. You wil melt the crank oil seal, and then you have a real big problem.
16-05-2021, 01:18 PM #20
Views 407
12-12-2022, 01:06 PM
Views 800
01-09-2020, 01:48 PM
Last Post by MKT222
Views 674
02-09-2019, 05:34 PM
Replies 31
Views 3,282
06-09-2018, 06:46 AM
Last Post by captain
