JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications lexus is 200 tte compressor problem
Alpine89
24-04-2022, 12:02 AM
I mean when the bypass is closed Smile
Alpine89
24-04-2022, 12:02 AM #11
24-04-2022, 06:13 AM
when the bypass is closed all air is forced through the charger so you should see boost at this point.
the bypass closes as you press the throttle
24-04-2022, 06:13 AM #12
Alpine89
24-04-2022, 06:27 AM
Thanks for the confirmation.
And no boost can I see, so something does not work: (
Alpine89
24-04-2022, 06:27 AM #13
Alpine89
27-04-2022, 12:13 PM
problem / problems solved Smile
The first had a tube released, and second error was a screw that prevented the damper to close rebound enough ..
Tested the car on the road but when I did kick down the car went into Limp Mode: (
Found error code reader and got the P1125 and P1128.
With the ignition on and after 3/4 throttle toothed wire on the intake damper over. There I found the error, the wire from the compressor was too tight ..
Now I can accelerate without fault codes with a pressure of 0.2 bar. Will set it right so the pressure falls between 0.3-0.4 Bar.
Alpine89
27-04-2022, 12:13 PM #14
27-04-2022, 03:43 PM
Glad you sorted it mate!
27-04-2022, 03:43 PM #15
Millo73
05-04-2024, 04:10 AM
Alpine89 Compressor is broken? I bought the kit of a person in the last week.
Bought new cable and tweaked it good but had in mind that it was not the fault ...
When the return valve closes and the full throttle, I get NO charge at all. I only see that it jumps up to 0.5 bar when I RELEASES on the accelerator for a second.
Normally it should be vacuum at idle and then boost as long as I push the gas.
Could there be something wrong with the compressor and what in that case?
Where did you get cable from
MeisterR low and hks silent is how to ride
Millo73
05-04-2024, 04:10 AM #16
Views 626
30-04-2023, 12:16 PM
Views 1,606
10-08-2022, 04:23 AM
Last Post by Jimbob-T-Lex
Views 495
07-03-2021, 06:38 PM
Views 1,452
01-04-2020, 02:53 PM
Views 1,173
28-03-2019, 08:56 PM
Last Post by ormi
Views 669
30-01-2019, 04:48 PM
Last Post by SXE10STU
Replies 29
Views 3,083
25-12-2018, 01:54 PM
Replies 56
Views 6,302
20-03-2018, 04:27 AM
