JapCarForum Car Manufacturers Lexus/Toyota Need help TTE s/c IS200
02-07-2023, 10:03 AM
They are def 1ggte/7mge injectors. And they are 315cc from all the data I've found.
02-07-2023, 10:03 AM #11
lygis
02-07-2023, 01:58 PM
What ecu could you recommend with these injectors, 160mm pulley and walbro fuel pump? emanage greddy any good?
lygis
02-07-2023, 01:58 PM #12
phaebo
02-07-2023, 02:56 PM
When i had the 310cc injectors with 155 pulley and patricks blackbox i had the problem when i accelerated part throttle when hitting small boost levels the car was overfuelling. That caused the car to stall and then got power again. I didnt have the problem with full throttle only on part throttle whith little boost. When this happened my air fuel gauge told me the car was running way too rich
Now i am running a greddy e manage ultimate and it is mapped on the dyno and now the car pulls great. This sounds a bit like the problem you are having. The 310cc injectors give to much fuel to handle for the oem ecu.
Greddy e manage ultimate is a good choise when it is mapped. I should give it a try.
I have 155mm pulley and have no problems with the oem fuelpump.
I think the oem pump will do fine for you
phaebo
02-07-2023, 02:56 PM #13
Views 1,008
06-01-2025, 09:27 PM
Last Post by liquidlazer
Views 1,259
05-01-2025, 02:15 PM
Last Post by bigdave1701
Views 590
08-10-2024, 09:10 PM
Views 749
03-10-2024, 06:27 PM
Last Post by CrocodileHunter
Replies 22
Views 2,304
26-07-2024, 05:33 PM
Replies 52
Views 4,639
14-07-2024, 03:30 AM
Last Post by Mr_Woods
Views 1,305
24-05-2024, 12:47 PM
Views 766
23-05-2024, 07:38 PM
Last Post by ViperTheLex
Views 1,037
19-05-2024, 12:51 PM
