JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza would this have enough tourq to open my crank bolt
Marcus_1UZ
26-08-2017, 06:09 PM
HI mate, what are you trying to remove the bolt? or the pully? one min you say the bolt will not move then you say the pully, you are trying to undo it the right way i ask?? as you said the car moves forward when you try to undo it, you car should only move forwoard when you try and do it up!!
ibby the issues is..
I bought a crank holder kit 45£,
breaker bar, and the pully will not shift.
The car moves forward with the yanking.. but the pully wont move
I have oiled it, bit the bolt with a hammer..
So I try the battery trick. it snapped and shreared two bolts..
so then I ordered an impact socket set
try it today.. battery trick, starter moves .. engine turns then hummmm
(when breaker bar hits the leg)
so now iam out of ideas!
I did buy an impact wrech with a gun from ebay which runs on air.
but i have no compressor!
Marcus_1UZ
26-08-2017, 06:09 PM #11
Marcus_1UZ
26-08-2017, 06:17 PM
aaronabbott give it some heat with a small butane blow torch then try
its not the bolt he needs to heat up! its the bit the bolt goes into but that bit has the pully on it, if he trys to heat the bolt up i sure it will just make it tight? "i think" please put me right if you think im talking out my back side:lol:
Marcus_1UZ
26-08-2017, 06:17 PM #12
26-08-2017, 06:42 PM
heating up the bolt will work too mate but you wont get enough heat in it with a small butane torch.
26-08-2017, 06:42 PM #13
ibby
26-08-2017, 06:48 PM
iam doing it the right way!
I double checked, but its been awhile maybe car was moving backwards.
ibby
26-08-2017, 06:48 PM #14
27-08-2017, 04:26 AM
ibby So I try the battery trick. it snapped and shreared two bolts..
What's the "battery trick" ? :confused1:
Have you tried the method where you use a breaker bar and brace it against the chassis, then quickly flick the starter on and off and that loosens it ? Or is that what you mean by the battery trick ? If you try that one you mustn't hold the starter on, you just need to do it very quickly.
27-08-2017, 04:26 AM #15
ibby
27-08-2017, 05:25 AM
steviewevie What's the "battery trick" ? :confused1:
Yes
thats the one.
Braced it against the chassis and flicked the key..
Ive bought a compressor now Blush
you'l have to blame marcus!
Edited 08-10-2009, 09:27 AM by ibby.
ibby
27-08-2017, 05:25 AM #16
Yes
thats the one.
27-08-2017, 05:27 AM
ok, so what was it that snapped and which bolts sheared when you tried that ?
27-08-2017, 05:27 AM #17
ibby
27-08-2017, 05:32 AM
steviewevie ok, so what was it that snapped and which bolts sheared when you tried that ?
well,
(iam on my own doing repairs)
so I ligned up timing to TDC,
I put the socket on the crank bolt
I put the wrench on the end of the bolt,
a brace it agaisnt the chassis leg,
go to the inside of the car, crank it
and the bar goes flying with the socket.
Bar is ok, but socket has been sheared Blush
so i ended up buying another set of sockets (impach wrench) do the same but the bolt still hasnt moved!
:ohmy:
ibby
27-08-2017, 05:32 AM #18
well,
:ohmy:
27-08-2017, 05:45 AM
ibby and the bar goes flying with the socket.
That's odd. Sounds like either the socket wasn't on square, or the socket was poor quality ?
27-08-2017, 05:45 AM #19
ibby
27-08-2017, 05:49 AM
steviewevie That's odd. Sounds like either the socket wasn't on square, or the socket was poor quality ?
Maybe the sockets were poor quality...
They were orginally my dads probably a good 15 ish years old
ibby
27-08-2017, 05:49 AM #20
Views 1,129
01-08-2020, 02:28 PM
Last Post by jasons
Views 988
14-05-2020, 10:55 PM
Last Post by Mr Reman
Views 1,747
28-11-2018, 11:57 AM
Views 1,200
17-06-2018, 04:42 PM
Replies 23
Views 1,996
25-12-2017, 06:07 PM
Last Post by ormi
