JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza TTE charged IS200 -problems - Misfire/ judder
Joff
30-08-2017, 08:27 AM
Sparkystav did your car used to work properly?
did you take it for a test drive before you bought it?
it is a possibility its been removed, you need to look for a Green wire with a red Tracer (line) on it. that wire needs to be cut when installing the FCD/tte black box so there should be a join in it if they've removed it.
yes worked fine on test drive, there was two boost leaks which i knew about so i didnt really boot it! got home fixed the boost leaks and then this problem happened!
going to have a look under the bay asap see if i can find the ecu or if its been removed!
Joff
30-08-2017, 08:27 AM #11
30-08-2017, 11:01 AM
It's probably got a TTE black box which has failed, since that's quite common, as others have said. If that's the problem it's easy to fix too, with an HKS FCD. Although those aren't quite as good as the TTE black box, they're massively cheaper ! And should do the job fine.
30-08-2017, 11:01 AM #12
Joff
30-08-2017, 12:00 PM
right there is definalty no tte black box inside the ecu, there is a black wire with a red tracer on it that has been cut and joined back together!
Joff
30-08-2017, 12:00 PM #13
30-08-2017, 12:04 PM
No sign of something else being connected into the ECU ?
Was it a private sale or a trader ? Wonder if they took it off because there was another problem ?
30-08-2017, 12:04 PM #14
Joff
30-08-2017, 12:07 PM
edit: also is the green wire with red tracer that has been cut and re joined and a blue wire with yellow tracer that has been rejoined!
i wonder why it was removed?:S
the previous owner was a chap called steve hardy! a lexusownersclub gold member!
was a private seller! its the car that was being spoke about in another thread! really cheap one off ebay! from bedford! someone test drove it when it was in manchester!
i bought it knowing about a boost leak or two, i thought that may be why it was slow! i have since sorted them and it does drive 100% better!
but obviously without this FCD then it wont rev above 4k so that doesnt help lol! just hope my problems are caused by not having an FCD!
Edited 11-10-2009, 03:55 PM by Joff.
Joff
30-08-2017, 12:07 PM #15
Joff
30-08-2017, 12:12 PM
what model do i order as i see there is a few?
thanks alot for the help everyone! been great!
its always the case when you buy cars with problems without knowing much about them lol!
you say when you drove it in manchester it was down on power? did it have the intercooler piping hanging off back then? and also one of the intake pipes had a split in it, since i have sorted that it responds and pulls alot better, even in snow mode! was worried as i the other thread you said you thought it may be the charger?
Joff
30-08-2017, 12:12 PM #16
30-08-2017, 12:14 PM
Hmm,
i wouldnt be forking out for one, i'd be contacting the seller!
you shouldnt have to fork out for something that should be there!
30-08-2017, 12:14 PM #17
Hmm,
30-08-2017, 12:16 PM
Yeah I'd be contacting the seller too and finding out where the black box went ! They are a bit pricey so it's very naughty *if* the owner cut it off and sold it !
To the other guys - is this the charged IS200 that was up for sale that was discussed in a thread recently ?
Edited 11-10-2009, 04:14 PM by steviewevie.
30-08-2017, 12:16 PM #18
30-08-2017, 12:17 PM
Joff what model do i order as i see there is a few?
It's the type "Standard" that Gord mentioned :wink:
30-08-2017, 12:17 PM #19
30-08-2017, 12:30 PM
Has it got a boost gauge ?
30-08-2017, 12:30 PM #20
Views 793
12-12-2024, 07:55 PM
Views 868
08-11-2024, 09:35 AM
Last Post by Dinho
Views 1,833
06-11-2023, 07:38 AM
Views 3,952
02-11-2023, 04:43 PM
Views 649
06-08-2023, 05:47 PM
Last Post by Brad92
Replies 38
Views 3,406
23-02-2023, 07:09 PM
Views 668
18-10-2022, 07:53 AM
Views 1,046
03-09-2022, 04:53 PM
Views 796
29-08-2022, 03:48 PM
Replies 35
Views 9,787
04-08-2022, 10:23 AM
Last Post by cjoseph
