JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! JDM fog mod(with out the yellow dome)
Chri5
31-12-2017, 06:37 PM
And poundland sell paint an primer for £1(bizzarely) a tin Smile
Chri5
31-12-2017, 06:37 PM #11
31-12-2017, 06:44 PM
you cna buy them from ebay aswell
31-12-2017, 06:44 PM #12
01-01-2018, 04:44 AM
yes and the same way.... heat them in the oven then pull them apart
01-01-2018, 04:44 AM #13
01-01-2018, 04:57 AM
i put mine in for 10 minutes then opened them up sprayed them up and then reheated them again and put the back together..... not so hard as it seams.... just put the oven on a low heat.. 125 c and watch the time. after i pulled them apart i used my finger to clean up the glue. by pushing it back onto the edge of the glass. so it goes back together without putting glue over the black painted cover
01-01-2018, 04:57 AM #14
01-01-2018, 02:20 PM
i used plastic primer.
01-01-2018, 02:20 PM #15
Chri5
02-01-2018, 02:39 PM
Right I got my primer and gloss black paint and laquor if I decide to use it.
But how do you get the fog lights out Sad ???
Chri5
02-01-2018, 02:39 PM #16
02-01-2018, 03:19 PM
first you release the 2 bolts on the inside of the lamps. if you look at the front of the light on the side are 2 no10 bolts on it once you have done that you need to release the wheel arch liner a little bit so take out the 2 poppers and get your hand behind it and take a torch and look at the back of the light you will see a plastic clip. get a flat screw driver behind it and release it then they just pull out
[Image: SDC11624.jpg]
[Image: SDC11626.jpg]
02-01-2018, 03:19 PM #17
Chri5
02-01-2018, 03:23 PM
Thank you Wink
I will give that a go 2morro when I've more patience and light Smile
Chri5
02-01-2018, 03:23 PM #18
Thank you Wink
Jambo
02-01-2018, 04:37 PM
I liked the microwave comment xD.
Looks like a good little mod here Smile Nice thread!
Latest Meets
Ace Cafe 16/10/10,
Jambo
02-01-2018, 04:37 PM #19
Latest Meets
Ace Cafe 16/10/10,
Chri5
02-01-2018, 04:48 PM
Does look a good mod and I want to know if the headlights cud be done in the same way???
Chri5
02-01-2018, 04:48 PM #20
