JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza led scuff plates.... group buy interest only
23-10-2017, 08:49 AM
I think it is TTE, not sure if they've been discontinued or not.
23-10-2017, 08:49 AM #11
25-10-2017, 04:17 PM
im sure they are TTE aswell. i will be interested but need some time to get money ready as im about to order a turbo
25-10-2017, 04:17 PM #12
25-10-2017, 04:39 PM
well have been looking into this and am getting a price from a laser cutting firm to see how much it will cost us to have our door plates done... i guess if i get them cut then i just need to glue some blue leds onto a plastic strip.
will let you know when i get the info back
about to do a turbo myself... what one are you going for...? the horsham one?
25-10-2017, 04:39 PM #13
25-10-2017, 05:05 PM
Asi im sure they are TTE aswell. i will be interested but need some time to get money ready as im about to order a turbo
Aren't you swapping the Soarer engine into your IS200 any more Asi ? Or is this to go along with that ?
25-10-2017, 05:05 PM #14
25-10-2017, 05:57 PM
steviewevie Aren't you swapping the Soarer engine into your IS200 any more Asi ? Or is this to go along with that ?
yep still doing swapping the engine out the soarer mate.
so the turbo is for that. i am going for a gt3076r with a .82 housing should spool quick with a good map.
25-10-2017, 05:57 PM #15
26-10-2017, 02:17 PM
so here you go..... talking to a guy that does laser cutting and will get a price for cutting the oem scuff plates so if you want i will fix the price for the whole set then you just have to fix the blue led lights under.....
will try and source a plastic cutter who can do the letters for it
let me know what you think
26-10-2017, 02:17 PM #16
26-10-2017, 02:49 PM
That definitely sounds interesting depending on price - although when you say the oem scuff plates do you mean the ones with all the holes in? Will that work with Lexus cut out of it?
26-10-2017, 02:49 PM #17
26-10-2017, 02:56 PM
will see. going to get them some photo's of them so they can see what they can do
26-10-2017, 02:56 PM #18
26-10-2017, 04:14 PM
Your probably better using the EL GLOW panels that you can get to light them up, its paper thin so will keep the thickness down for the panel itself,
If you get the lexus panel cut with just the lettering then fix the EL glow panel underneath it, and wire it through the inverter that comes with the panel to the car itself? EL PANEL CLICKY? used some of this when i did my EL Glow badges for the is200, if you search for the panels you can get them quite cheap :thumbup1:
Here's one of the badges i made with the EL Glow tape stuck to the rear..
Looked better in the red that i did?
[Image: lexbadgegreenelglow.jpg]
26-10-2017, 04:14 PM #19
26-10-2017, 04:37 PM
just got one of them.... will give it a try....
just about this i see it has 4 contacts but i guess you can cut all the others of?
26-10-2017, 04:37 PM #20
Views 779
27-12-2020, 06:10 PM
Last Post by purplewitch
Views 989
10-07-2018, 12:22 PM
Views 2,173
28-01-2018, 08:23 AM
Last Post by N2KHL
Views 3,811
02-12-2017, 02:39 PM
