JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza headlight prob!
headlight prob!
headlight prob!
29-11-2017, 05:32 AM
Rabster hmmm ummm have you checked continuity from the conector plate to the cable this can be done with a multimeter and a stanley knife
no need to cut the cable just use a sharp blade and hold the vable on the blade it will make a connection if there is continuity
Ooh, nice tip, never thought of that before :thumbup1:
29-11-2017, 05:32 AM #11
29-11-2017, 08:40 AM
yeah thats what i thought, no need to bare any cable all the time etc as it will self heal from a tiny blade cut
29-11-2017, 08:40 AM #12
widnes_is200
29-11-2017, 12:14 PM
right all wires re wired, butt this is the prob , no dipped beam at all butt if i earth out the red and purple wire on the multiplug or earthout the same wire on the stalk the dip come on so has anybody any idea at all?, im thinking of trying replacing the stalk next butt dont know, has anybody got a wire diagram for the light stalk at all? cheers
widnes_is200
29-11-2017, 12:14 PM #13
29-11-2017, 12:17 PM
ok so if you earth it out it works what if you check for power on that cable when you switch the lights/dip beam on ? do you get anything
if not then yes the stalk is at fault if you do then its something else...
29-11-2017, 12:17 PM #14
aaronabbott
29-11-2017, 12:18 PM
i replaced my theft control unit which controls the lights and tons of other things and that has done the trick
aaronabbott
29-11-2017, 12:18 PM #15
widnes_is200
29-11-2017, 12:28 PM
Rabster ok so if you earth it out it works what if you check for power on that cable when you switch the lights/dip beam on ? do you get anything
its eems to be constantly live both at the multiplug and stalk when earthed lites come on dip, head wrecking now!
widnes_is200
29-11-2017, 12:28 PM #16
29-11-2017, 12:51 PM
The wiring diagram for the headlights (2001 onwards) is here.
29-11-2017, 12:51 PM #17
widnes_is200
29-11-2017, 01:02 PM
cheers steve, ive just been looking at the theft control unit and the same wire ive been checking goes into this. tempted to try this while theres one at the brakers, what do u think?
widnes_is200
29-11-2017, 01:02 PM #18
29-11-2017, 01:05 PM
I would pick it up and give it a go, especially since Aaron found it sorted his problem out.
29-11-2017, 01:05 PM #19
aaronabbott
29-11-2017, 01:49 PM
it worked for me,the fault in the fuse board caused the theft control unit to short causing the lights to fail
aaronabbott
29-11-2017, 01:49 PM #20
Views 793
12-12-2024, 07:55 PM
Views 693
31-10-2020, 07:50 PM
Last Post by rigga
Views 1,334
27-08-2020, 07:55 PM
Replies 25
Views 2,153
07-08-2020, 07:00 PM
Last Post by Chris0121
Views 1,434
07-08-2020, 03:11 PM
Views 480
08-05-2020, 06:28 PM
Last Post by jasons
Views 1,019
07-03-2020, 04:36 AM
Last Post by nimrodmk3
Views 919
21-12-2019, 06:25 PM
Last Post by is300_dino
Views 2,056
04-07-2019, 09:10 AM
Last Post by mattross1313
