JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Air Filter
Air Filter
Air Filter
27-01-2018, 06:47 PM
K&N is a no-brainer upgrade IMHO. Helps fuel economy a bit, sounds slightly better, doesn't cost much (you need air filters anyway) and you know the engine is breathing better.
Andy-R. TBH mate forced indution doesn't give hardly any extra power just sounds better.
Think there might be a misunderstanding here, forced induction is where you force the induction air in, e.g. supercharger or turbocharger. Were you thinking just of an induction kit ? Because then as you say it just makes it sound different really.
27-01-2018, 06:47 PM #11
James S
28-01-2018, 05:28 AM
EEK! Problems, not sure if this is filter related. But.....
If i thrash the car for a few mins, then come to a stop at some lights or something, the car isn't idling properly. It sounds like its about to cut out! Is this normal????? HELP please
James S
28-01-2018, 05:28 AM #12
28-01-2018, 05:35 AM
No, it's not normal. Did you reset the ECU soon before that ? If not, give that a go. If you did, might be part of the learning process ?
I assume this didn't use to happen before you changed the filter ? Might be worth double-checking that it's in place properly.
28-01-2018, 05:35 AM #13
deckie77
28-01-2018, 05:37 AM
No not normal at all.
If filter is all that you've changed recently then i'd start there, were you careful when replacing the filter that no debris went past the filter??? i know i pulled out leaves & hoovered out some dust before fitting mines.
Did you re-set your ecu???? i re-set mine but it just may be yours coming to terms with the new filter???
EDIT - Stevie beat me to it.
Edited 11-03-2010, 09:23 AM by deckie77.
deckie77
28-01-2018, 05:37 AM #14
28-01-2018, 05:38 AM
No when you come to a stop the idle should stay at one place and not move.
28-01-2018, 05:38 AM #15
James S
28-01-2018, 07:32 AM
Yes I reset the ecu. It has done it before, but only once or twice. It doesn't happen everytime either. And will sit at idle fine when just started, or I haven't been driving hard.
A friend at work has said it could be the MAF sensor, going to clean the airbox out when I get home tonight. And see if there is any dust on the sensor.
James S
28-01-2018, 07:32 AM #16
Andy-R.
28-01-2018, 08:02 AM
The K&N is a tight fit make sure it's in place properly and the filter housing is sitting correctly in the air box.
[Image: Lf9Nl.jpg]
Andy-R.
28-01-2018, 08:02 AM #17
[Image: Lf9Nl.jpg]
James S
28-01-2018, 02:22 PM
I had a quick clean round the MAF sensor on my lunch, and car was fine on the way home.
Its a good improvement too, the old filter was well due for replacement, taken a while to bed in, but worth the hassle. :w00t:
James S
28-01-2018, 02:22 PM #18
28-01-2018, 05:24 PM
The IS200 doesn't have a MAF sensor (it has MAP instead).
28-01-2018, 05:24 PM #19
James S
29-01-2018, 05:09 AM
Ok, well the sensor just inside the air box, I cleaned that, and all is well LOL! :w00t:
James S
29-01-2018, 05:09 AM #20
Views 1,515
25-05-2018, 05:46 AM
