JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza The time has come....2JZ questions ;)
06-02-2018, 07:21 AM
Awesome project Sam, which box you got the 160 or 161?
06-02-2018, 07:21 AM #11
06-02-2018, 07:27 AM
+1 for the wiring fun you're looking at. The instrument cluster is complex on the IS, it's all multiplex with bits of canbus thrown in as well, not to mention the ridiculous thing with monitoring injector usage to compute the fuel gauge Wink Plus *everything* runs through the ECU, even the exterior temperature gauge as we found out on that other thread...
Is the supra motor VVTI? Can the F-CON run VVTI or will you be looking at updated management?
Edited 20-03-2010, 11:16 AM by toxo.
06-02-2018, 07:27 AM #12
06-02-2018, 08:10 AM
Sounds like an awesome project sam.
I can understand the need for the IS ecu to runs the ancillaries (speedo, etc, even the aircon!) but why the supra one?
I would hugely recommend the LINK brand ECUs
06-02-2018, 08:10 AM #13
06-02-2018, 09:37 AM
I have a feeling my Aircon is run through the Apexi (the A/C wire is connected) - it should raise the RPM in idle with A/C on. If it doesn't you may stall the engine if you use A/C on idle.
06-02-2018, 09:37 AM #14
06-02-2018, 10:05 AM
but the Lexus ECU also engages/disengages the clutch for the aircon, and has to do it ever few seconds to stop it freezing over
06-02-2018, 10:05 AM #15
06-02-2018, 10:23 AM
yea the Apexi takes care of it all, one of the features it has.
06-02-2018, 10:23 AM #16
06-02-2018, 10:26 AM
but itll still need the signal from the Lexus ecu to know when to turn on/off as the aircon ecu sends it via multiplex to the Lexus ECU
06-02-2018, 10:26 AM #17
06-02-2018, 10:41 AM
Its not a Lexus Air con pump - its an MR2 one, if that makes any difference. I have personally been in it when the A/C was running and it all worked fine. Maybe there is feed to/from the Lex ECU also?
06-02-2018, 10:41 AM #18
06-02-2018, 05:23 PM
Sam B hmmm may have many questions for you then haha!
Sure mate, no problem Confusedmoke:
06-02-2018, 05:23 PM #19
Sam B
07-02-2018, 08:33 PM
no idea yet really but id be open to offers Smile
[Image: DWSIG2.jpg]
Sam B
07-02-2018, 08:33 PM #20
[Image: DWSIG2.jpg]
Views 645
07-05-2020, 07:09 AM
Last Post by jomo
Views 746
06-02-2020, 06:41 PM
Last Post by Stoney
Views 1,302
23-01-2020, 06:11 PM
Last Post by reco2k
Replies 26
Views 2,341
09-09-2019, 01:04 PM
Last Post by Stoney
Views 1,699
07-09-2019, 06:29 PM
Last Post by clossie
Views 1,349
12-07-2019, 11:15 AM
Last Post by sprinter2012
Views 468
04-07-2019, 03:35 PM
Views 1,295
29-03-2019, 07:09 PM
Last Post by Fry-Up
Views 1,266
05-07-2018, 04:06 PM
Last Post by Protok
