JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Engine & Transmission Engine Covers
Engine Covers
Engine Covers
Jambo
08-03-2018, 07:09 PM
I was going to write that...... very close for a guess :|. yey!!
Latest Meets
Ace Cafe 16/10/10,
Jambo
08-03-2018, 07:09 PM #11
Latest Meets
Ace Cafe 16/10/10,
The cover is something i made out of sheet steel, then i sprayed the sun pattern onto it, also sprayed all the engine covers to follow on the design so it looked all one pattern:thumbup1:
08-03-2018, 07:09 PM #12
09-03-2018, 03:03 AM
Bandit you should do a group buy on these, i sure your get a few people wanting them:thumbup1:
09-03-2018, 03:03 AM #13
09-03-2018, 04:19 AM
Trouble is that it depends on your induction kit etc, so I'm not sure a single cover would fit lots of different cars, unless you made it quite small and only covering part of the engine. I could be wrong though !
09-03-2018, 04:19 AM #14
garyskisplym
09-03-2018, 06:20 PM
See at the min need to keep mine as still got standard filter.
May try and get a scrap piece of metal from mate and see if can fit it over standard over.
Also when fitting an induction kit do you have to loss the original cover??
I know it have filter in standard but was thinking just taking it off, cutting pipe to t/b off then hole in top for pipe to come out.
garyskisplym
09-03-2018, 06:20 PM #15
09-03-2018, 07:19 PM
yip matey it has to come off the cover is the air box and prob not a good idea to start drillin holes/cutting uo as it prob wont work...?
09-03-2018, 07:19 PM #16
13-03-2018, 02:06 PM
i did what bandit had done it easy to make you just have to make a template first i did mine in 1.5mm alloy sheet not as good as bandits with colour and all that but not bad for a first go
13-03-2018, 02:06 PM #17
Views 422
15-04-2023, 09:06 AM
Views 570
15-01-2023, 08:08 AM
Views 1,110
17-08-2022, 09:38 AM
Last Post by mattlaw
Views 662
23-04-2021, 03:50 AM
Last Post by S
Views 971
01-04-2021, 08:42 AM
Views 446
10-03-2021, 05:19 AM
Views 1,175
14-11-2020, 09:36 PM
Views 884
25-06-2020, 04:13 PM
Replies 18
Views 2,125
20-02-2020, 01:03 PM
Views 2,073
18-11-2019, 10:04 AM
