JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications HKS FCD install
HKS FCD install
HKS FCD install
Fredrico
06-04-2018, 11:25 AM
It's installed now. Really happy with thw car now that it has a bit more power. The only thing i have to do now is to move the intercooler a bit as it interfears with my front bumper.
The bypass valve on the SC, is the wire supposed to be a bit loose? And is there anyone else than me who can feel a small decrese in power at around 3000 rpm? Will try to take some pics and upload :biggrin:
Fredrico
06-04-2018, 11:25 AM #11
06-04-2018, 11:40 AM
yeah theres meant to be slack in it mate
06-04-2018, 11:40 AM #12
edeath
06-04-2018, 12:05 PM
I had the same power problem which was fixed by 11 on the FCD and an uprated fuel pump. Does it stutter if you floor it at 2000rpm and keep it going untill it goes past 3000rpm. I found the power hole was about 2,750rpm but only on 90-100% throttle and there is no boost change.
Have you installed the IK22 plugs? Might be worth trying the old ones.
Edited 18-05-2010, 03:57 PM by edeath.
edeath
06-04-2018, 12:05 PM #13
Fredrico
06-04-2018, 12:20 PM
edeath I had the same power problem which was fixed by 11 on the FCD and an uprated fuel pump. Does it stutter if you floor it at 2000rpm and keep it going untill it goes past 3000rpm. I found the power hole was about 2,750rpm but only on 90-100% throttle and there is no boost change.
Yes, i have the same problem as the one you describe. Have not installed the new spark plugs, but i'm considering doing that today.
Have not gotten my new gauges yet, so i don't really have any control with the boost level.
Fredrico
06-04-2018, 12:20 PM #14
edeath
06-04-2018, 01:55 PM
You could always plug the boost guage I sent temporarily to check it?
I found on my car that the "power hole" gets better the more the ECU learns the charger and also gets much better once the car is warmed up and pretty much dissappears once youve done 10-20 miles (unless you try and catch it out on purpose). As I said before I did get this sorted - as apparently it is fuel delivery thats the problem.
Did you reset the ECU after you installed the SC? You definitely need to reset the ECU after the IK22 spark plugs or it missfires.
edeath
06-04-2018, 01:55 PM #15
Fredrico
12-04-2018, 10:34 AM
edeath You could always plug the boost guage I sent temporarily to check it?
I have not reset the ECU, but i'm considering to try that. Did you change your fuel pump? What pump did you change to? And was it a plug and play swap? Did you have to install a fuel pressure regulator?
Fredrico
12-04-2018, 10:34 AM #16
12-04-2018, 10:46 AM
I haven't changed my fuel pump or added another FPR, and my turbo'd car has more power than the supercharged versions. So I can't see why an s/c would need one, unless the existing ones were faulty anyway.
12-04-2018, 10:46 AM #17
Fredrico
12-04-2018, 11:28 AM
steviewevie I haven't changed my fuel pump or added another FPR, and my turbo'd car has more power than the supercharged versions. So I can't see why an s/c would need one, unless the existing ones were faulty anyway.
No, i think it quite strange aswell.
Have now gotten my two autometer gauges. But where is it you are supposed to T off with the vacuum hose? And if i change to the induction kit, what should I do with the intake temp sensor?
Thanks for all replys so far. Has been very helpful, a good forum:thumbup:
Fredrico
12-04-2018, 11:28 AM #18
edeath
14-04-2018, 10:43 AM
Apparently it was a 225 fule pump -not sure which one - but did not have to install an FPR.
I would reset the ECU as it will take a pretty long time to fully learn the charger. I'd reset the ECU before you try anything else to fix the stutter.
edeath
14-04-2018, 10:43 AM #19
Fredrico
14-04-2018, 03:07 PM
Reseted the ECU two days ago, but the problem does not seem to get better. But I will have to see how the issue is developing, if it becomes better.
Got the last of my gauges today, so thinking about installing them tonight or when i get back from work again next week. Been waiting so that i can pull all the wires togheter rather than having to redo something later.
Also ordered an oil filter relocation kit to get an output for the oil pressure sensor and to relocate the oil filter from it's original location since it's a pain in the ass to change.
Fredrico
14-04-2018, 03:07 PM #20
Views 932
03-12-2021, 03:27 PM
Replies 55
Views 5,218
11-07-2019, 11:31 AM
Last Post by Stoney
Views 1,896
16-01-2019, 06:23 PM
