JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Workshop - Submit Your Tip! Changing Spark Plugs on an IS200
20-09-2018, 06:12 AM
By the way, the reason the IK22s are typically used on forced induction cars is because of the higher temperatures that these plugs are likely to experience during combustion. If you ran IK22s in a normal engine, you might find that they don't get heated up enough, and therefore are more prone to fouling up with carbon deposits. Similarly if you ran IK20s in a turbo'd engine then you might find you are more prone to pre-ignition.
20-09-2018, 06:12 AM #11
Dave
06-10-2018, 01:13 AM
Hi guys should be getting my tools for x mas and then the new plugs soon thereafter. I read on a website that u have to set a gap for the plug. if the gap is to big or small it can cause problems. Can anyone shed any light on this thanks in advance.
Dave.
Dave
06-10-2018, 01:13 AM #12
Dave.
Dave
06-10-2018, 01:23 AM
*test to see if sig works*
[SIGPIC][/SIGPIC] LEXUS IS200 SE 2002. WOULD LOVE 2 KNOW HOW MANY IS200'S ARE IN THE UK.
Dave
06-10-2018, 01:23 AM #13
06-10-2018, 03:06 AM
Dave Hi guys should be getting my tools for x mas and then the new plugs soon thereafter. I read on a website that u have to set a gap for the plug. if the gap is to big or small it can cause problems. Can anyone shed any light on this thanks in advance.
Dave.
Most sparks come pre set now so it shouldnt be an issue
06-10-2018, 03:06 AM #14
Dave.
06-10-2018, 06:50 AM
good walk through mate
06-10-2018, 06:50 AM #15
Dave
07-10-2018, 11:40 AM
hi i managed to get all the covers off, then the socket came off the ratchet! and went to the bottom, now i cant see it, think it may be on the undertray, should i be worried if i cant get this thing out.
Dave
07-10-2018, 11:40 AM #16
Dave
07-10-2018, 11:43 AM
also if i have the keys in the ignition listening to music, is there any chance i could electricute myself Confusedcared:
Dave
07-10-2018, 11:43 AM #17
07-10-2018, 11:56 AM
Doh ! Yes, it's probably on the undertray. Have you got one of those extended reach tool thingies, a kind of spring on a long rod that you can use to pick things up in tight places ? You can get them from Halfords etc.
You should be ok if you've only got the key in the "ACC" position, i.e. just so the radio is on. Make sure the ignition isn't on at all though.
07-10-2018, 11:56 AM #18
Dave
07-10-2018, 11:59 AM
no i havent got one sadly. I think I shall defo not have key in at all then just in case, not to bothered about the socket as long as it dont get mangled up in anything and wreck the car
Dave
07-10-2018, 11:59 AM #19
26-10-2018, 05:24 PM
Yes they can as far as i know
26-10-2018, 05:24 PM #20
Views 407
13-12-2023, 11:46 AM
Replies 46
Views 9,711
16-03-2023, 05:51 AM
Last Post by Emissary
Views 971
24-01-2020, 07:55 PM
Views 3,260
03-10-2019, 02:22 PM
Replies 24
Views 3,823
19-07-2019, 04:46 PM
Replies 41
Views 5,181
10-04-2019, 05:07 AM
Last Post by IanS200
Views 1,136
23-01-2019, 01:07 PM
Last Post by Jambo
Views 3,262
27-10-2018, 12:03 PM
Views 1,769
28-08-2018, 06:06 PM
