JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Fitting Guide for Mkiv Supra Twin Turbo Brakes onto an IS200
05-05-2018, 10:58 AM
purplewitch24 I can tell you, certainly on the Supra, getting wheels to fit over them is an absolute nightmare ... all the ones I like won't fit. Found some I don't mind but I still don't have full wheel lock.. so when you see me doing a 27 point turn, it's not because I'm a girl, it's because I want to have tyres left at the end lol
have that with the MR2, on full right hand side lock the rubber rubs the inner arch.
05-05-2018, 10:58 AM #11
05-05-2018, 11:03 AM
oi you ! Between my front splitter being lower than the kerb and no full lock, I have to be careful.. three point turns and reversing is easy peasy .. I'm good at them.. it's parallel parking I'm a girl at .. luckily I don't go anywhere where I have to lol
05-05-2018, 11:03 AM #12
ToyMr2
04-06-2018, 01:07 PM
Nice writeup! I have had the FIGS adapters for a while now, but never bought the Supra calipers.... (have the disks though...)
I also have a TIP so that you guys don't spill so much brake fluid when changing the caliper:
Put light pressure on the brake pedal, and lock it there. (not all you got, but so much that the wheels don't turn freely). I usually use some wood block against the seat.
When you do this, there will come almost no fluid out the brakehose at all! Smile
ToyMr2
04-06-2018, 01:07 PM #13
04-06-2018, 01:16 PM
ToyMr2 Nice writeup! I have had the FIGS adapters for a while now, but never bought the Supra calipers.... (have the disks though...)
Handy Tip!
04-06-2018, 01:16 PM #14
Handy Tip!
Kerja
17-04-2019, 05:55 PM
two quick questions...
can the supra calipers be used over Lexus brake discs, or brake discs come from Supra as well?
and would this setup allow to put 17-inch 5 spoke wheels back on without problem?
Ta
Kerja
17-04-2019, 05:55 PM #15
Ta
17-04-2019, 06:28 PM
Hi mate,
no you have to use Supra discs.
and yes you can put the 5 spoke 17's back on, BUT you need 15mm spacers to get them on.
17-04-2019, 06:28 PM #16
Hi mate,
Kerja
17-04-2019, 07:26 PM
oh, ok, makes sense now Smile 'cos I wanted to keep them 5 spoke 17'th for winter usage (with winter tires obviously)
I'll be on the hunt for ones in that case Smile
Cheers Sparky
Kerja
17-04-2019, 07:26 PM #17
Cheers Sparky
Views 493
16-06-2023, 09:40 AM
Views 1,312
28-04-2022, 06:35 AM
Views 598
15-02-2022, 12:32 PM
Last Post by Lance79
Views 1,743
29-04-2021, 05:16 AM
Views 1,408
10-11-2020, 07:29 AM
Views 710
09-08-2020, 04:24 PM
Views 1,205
18-06-2020, 04:50 PM
Last Post by Mr Reman
Views 710
05-03-2020, 06:08 PM
Views 384
05-03-2020, 05:28 PM
Last Post by spikes
Views 1,305
10-02-2020, 11:08 PM
Last Post by ormi
