Replacing Number Plate Bulbs
Chri5 that looks a lot of effort just to change number plate bulbs.
get yourself a nissan lol
tools required phillips screwdriver.
umdo 4 screws (2 on each lense)
remove lense
remove bulb
refit bulb
refit lense
redo 4 screws (2 on each lense)
job done now sit back and admire your new bulbs lol
remove lense
remove bulb
refit bulb
refit lense
Wish i had read this before attempting this job this evening :crying:
I figured out to remove the boot lining and then to undo the 2 outer 8mm bolts, then i wiggled the bar and felt it was still taught in the middle, i did'nt think the central 2 8mm bolts would be part of it because they appeared to be holding the boot release mechanism to the boot skin.
So i pulled a little harder and heard "craaaaaaaack" :crying:
Yup my bar is now in 2 pieces.... Some super glue and tlc later and its looking ok, just  not perfect if you know what i mean, what a silly ****** way of fitting number plate lights Toyota!
Rant over ............
