JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza maf sencor help
maf sencor help
maf sencor help
29-09-2018, 04:13 PM
jay_russell so am i looking at the vacum sensor.... maf or air tempture maf.
what one is the maf sensor
If it's an IS200 then you don't have a MAF sensor, you have a MAP sensor (vacuum sensor on that diagram).
29-09-2018, 04:13 PM #11
29-09-2018, 04:15 PM
so this might have lost it's hose then or would it be a cleaning thing
29-09-2018, 04:15 PM #12
29-09-2018, 04:29 PM
You shouldn't need to clean it. Could be worth checking the hose is still on.
What extra kind of MAP do you have to handle the turbo ?
29-09-2018, 04:29 PM #13
29-09-2018, 04:31 PM
I doubt it's the hose coming off the stock sensor though. Sounds like the stock ECU is seeing too much boost.
29-09-2018, 04:31 PM #14
29-09-2018, 04:32 PM
not sure as i did not fit the ecu. but there was one with the piggy back ecu so i guess it was fitted.
29-09-2018, 04:32 PM #15
29-09-2018, 04:34 PM
it's only started when it got cold over here. -1 or so. so thats why i'm not sure whats going on. have looked over the car and all the hoses seem to be ok.
29-09-2018, 04:34 PM #16
29-09-2018, 04:39 PM
ok that sounds odd. That's the kind of thing that happens on a supercharged car if the black box goes wrong, i.e. the stock ECU sees too much boost.
When it's colder the air is denser, I don't know if that is going to affect things for you at all. Normally that's a good thing in that the denser/colder air will burn better, but whether it's tipping something over the edge in your mapping ? I don't know. If there's another MAP sensor it's probably connected into the same hose as the stock MAP sensor.
What error code was it exactly ?
29-09-2018, 04:39 PM #17
29-09-2018, 05:00 PM
cant remember but it was to do with vacum circut
29-09-2018, 05:00 PM #18
29-09-2018, 05:03 PM
will put it on the tester again tomorrow lunch and write them down this time
29-09-2018, 05:03 PM #19
29-09-2018, 05:22 PM
Does it happen all the time now, i.e. you can never get past 3000 rpm without going into limp mode ? Or is it intermittent, and sometimes works fine ?
29-09-2018, 05:22 PM #20
