JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Cold starting
Cold starting
Cold starting
aaronabbott
05-10-2018, 12:22 AM
not of the top of my head,might be 17mm
aaronabbott
05-10-2018, 12:22 AM #11
Fozzy
05-10-2018, 06:32 AM
You will need a 10mm to remove the coil packs, and its the larger of the two tyes of spark plug socket, 16/17mm iirc
2009 JAE Car Pull Runner Up
2010 JAE Car Pull Failure
Fozzy
05-10-2018, 06:32 AM #12
05-10-2018, 10:52 AM
There's a walkthrough on changing the spark plugs on an IS200 at http://www.outlawjapclub.co.uk/forum/sho...d.php?t=24
The first really cold weather of the year will often kill a battery that is starting to fail.
05-10-2018, 10:52 AM #13
Dave
05-10-2018, 01:10 PM
thanks guys. stevie i tried to remove the just the covers today to take it step by step. I had a problem removing the bolt for the airbox located at the top right. could not fit a spanner and the hex key was not great as couldnt turn it. any good tools you can recommend to get this bolt out?
Dave
05-10-2018, 01:10 PM #14
05-10-2018, 01:56 PM
Dave thanks guys. stevie i tried to remove the just the covers today to take it step by step. I had a problem removing the bolt for the airbox located at the top right. could not fit a spanner and the hex key was not great as couldnt turn it. any good tools you can recommend to get this bolt out?
Sounds like you need a basic socket set with an extension, e.g. like I'm using here (though that pic has a spark plug socket on the end) :
http://i5.photobucket.com/albums/y179/St...plugs7.jpg
05-10-2018, 01:56 PM #15
Argh, trying again :
[Image: plugs7.jpg]
05-10-2018, 01:56 PM #16
[Image: plugs7.jpg]
aaronabbott
05-10-2018, 02:58 PM
^^ LEXUS ^^ was only £58Smile
aaronabbott
05-10-2018, 02:58 PM #17
05-10-2018, 04:17 PM
Out driving my car a short while ago, and I noticed that when it's idling the voltmeter dips noticeably when the heated rear screen is switched on. I think it might be time to invest in a new battery myself !
05-10-2018, 04:17 PM #18
Dave
05-10-2018, 08:45 PM
yeah i work 24 hour shifts so the last thing i want is after 9 hours at work finishing at 7am not being able to go home cuz the car wont start. i think i would :crying:
Dave
05-10-2018, 08:45 PM #19
Dave
05-10-2018, 08:46 PM
how often should a battery be changed?
Dave
05-10-2018, 08:46 PM #20
Views 1,658
20-08-2019, 05:25 PM
Views 1,097
17-03-2019, 04:48 AM
Views 945
09-11-2017, 07:21 AM
Last Post by Dan_Turism0
Replies 33
Views 3,193
19-10-2017, 02:16 PM
