JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension rear rollbar woes, need some help
19-08-2019, 05:55 AM
I hope to change the ARBs on my 2000 car (after I find the money and then find the ARBs!) Figured the fitting would be straight forward, but none of the guys are filling me with confidence! I've had a bout enough stuck nuts and sheared bolts already for one year! :lol:
19-08-2019, 05:55 AM #11
Phil01
19-08-2019, 06:36 AM
Stoney be prepared for at least ine broken bolt. if it does shear then simply drill it out. the bolts are soft metal and will be out in less than a few mins then fit a new nut and bolt. Do not even bother with eazi outs etc. I then coated new bolt with a coating of copper grease to prevent future corrosion
Phil01
19-08-2019, 06:36 AM #12
20-08-2019, 03:08 PM
Right, I'm absolutely ready to petrol bomb my car and buy a new one, because this has wasted 4 hours of my friggin time already.
[Image: nPMa3.jpg]
This bolt. It's spinning freely, moving back and forth about 2mm, but it seems to be somehow welded into the drop link that sits inside the subframe. If anyone has any ideas, including firing a ******* cannon at it, I'm all ears.
Tried bashing ten shades of **** out of it, tried turning it, wiggling it, attaching a friggin hammer drill to the bolt itself but nothing is shifting it at all. Don't say angle grinder because that won't help me at all, unless you can somehow angle grind the bolt inside the drop link without damaging the subframe.
Missed a ******* wedding because of this ****.
Edited 01-10-2011, 06:54 PM by el_bandido.
20-08-2019, 03:08 PM #13
[Image: nPMa3.jpg]
20-08-2019, 10:17 PM
Sorry if I've missed something, but can you not just grind off the part of the bolt you can see in the picture, and then knock the bolt through with a screwdriver and a hammer?
20-08-2019, 10:17 PM #14
21-08-2019, 12:54 AM
Or just drill it out.
21-08-2019, 12:54 AM #15
rob
21-08-2019, 05:57 AM
does it rotate freely? and i dont mean move left right a bit, i mean totally free to spin 360?
if it does and its still not coming out then the bolt and bushing in the roll link have rusted together and the bushing has seperated from the roll link.
i would suggest either heating the bolt or cutting the head and tail off the bolt flush and then pulling it out of the suspension arm. OR removing the suspension arm and then heating the link. make sure you can loosen the bolt holding the arm to the chassis though as these are very tight.
rob
21-08-2019, 05:57 AM #16
22-08-2019, 03:25 PM
rob does it rotate freely? and i dont mean move left right a bit, i mean totally free to spin 360?
This.
7 hours of hitting it with a hammer and swearing a lot finally sorted it.
22-08-2019, 03:25 PM #17
This.
Views 359
15-07-2021, 12:05 PM
Last Post by Mr-cth
Views 665
12-03-2021, 04:27 PM
Last Post by James S
Views 1,054
29-07-2020, 01:49 PM
Views 1,217
03-06-2020, 11:51 AM
Views 560
22-04-2020, 04:22 AM
Views 1,102
12-07-2019, 04:01 AM
Views 2,097
06-07-2019, 03:49 PM
Last Post by Stoney
Replies 24
Views 2,644
13-02-2019, 07:03 AM
Last Post by Phil01
Views 1,959
10-08-2018, 05:36 PM
Last Post by iano21
Views 1,241
29-04-2018, 06:35 PM
Last Post by Timbo
