JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza MOT time
MOT time
MOT time
clossie
06-09-2019, 07:06 PM
northernmonkey I'd love to know which MOT tester gives advisories for brake fluid and a coolant change, just so I can stay away from them!
Jeez......
I had a service at the same time. That's where the advisory came in. Mot sailed through..sorry did mention it in t first post...probably could have been clearer...
clossie
06-09-2019, 07:06 PM #11
Jeez......
clossie
06-09-2019, 07:08 PM
davidjamesbattersby what i was trying to figure out is did they test for this or just say, as there is ways and devices that you can use to check what the moisture content is in the brake fluid, iv never known this be checked on a mot so was just a bit puzzled with them giving you a advisory for this as its a quiet time for some garages and they might just be trying to get some work out of you, when people hear that there might be some thing wrong with your brakes as a example they panic and day just do the work needed
Oh don't worry... They didn't do the work... And as per previous..I had a service at the same time (hence the advisory) you are both right, an mot wouldn't have picked this up.
clossie
06-09-2019, 07:08 PM #12
davidjamesbattersby
06-09-2019, 07:13 PM
thats ok then, every car has the potential to absorb mosture, even brand new ones what you need to know is at what stage is your brake fluid at now, and as for the coolant go to a local motor factors and give them your reg number, they will be able to tell you what anti freeze you need and then follow instructions on the back, i normaly use 50/50 mix so once drained flush through with hose then fill up with right mix( always handy to premix ) then run engine at idle with heater on hot and face vents open til it blows hot and leave it running to allow any air locks to escape, once hot air coming out you know the thermostat is open and should be ok then
davidjamesbattersby
06-09-2019, 07:13 PM #13
clossie
06-09-2019, 07:28 PM
davidjamesbattersby thats ok then, every car has the potential to absorb mosture, even brand new ones what you need to know is at what stage is your brake fluid at now, and as for the coolant go to a local motor factors and give them your reg number, they will be able to tell you what anti freeze you need and then follow instructions on the back, i normaly use 50/50 mix so once drained flush through with hose then fill up with right mix( always handy to premix ) then run engine at idle with heater on hot and face vents open til it blows hot and leave it running to allow any air locks to escape, once hot air coming out you know the thermostat is open and should be ok then
Cheers.
Question for ya... I've seen a couple of recommendations to empty cool, fill back up just with water, run for ten mins, cool, drain and then fill up with antifreeze. What dya reckon? I'm sort of put off of using chemical flush incase I screw the pooch so to say..
clossie
06-09-2019, 07:28 PM #14
Cheers.
davidjamesbattersby
06-09-2019, 07:41 PM
i wouldnt use chemical flush either, id just drain, flush then refill with new antifreeze, auto data says its 7.1 so 3 and half ltr off both then just run it till its up to temp with the radiator cap off to allow any air bubbles and air locks to escape
davidjamesbattersby
06-09-2019, 07:41 PM #15
cornishlexus
07-09-2019, 05:03 PM
hi your brake fluid wuold of been checked for boiling point 155 degrees is the lowest point for a recomended chhange really you want it over 200 the lower the boiling point the more water in it and two years is just a recomended time to change the boiling point they found will be recorded on the sheet they shod of gave you as for the coolant chage is easy to do if you can be bothered although it is not that cheap to buy a good quality one hope this helps and clears things up a bit for you
cornishlexus
07-09-2019, 05:03 PM #16
clossie
07-09-2019, 06:29 PM
Cheer cornish
clossie
07-09-2019, 06:29 PM #17
Cheer cornish
Views 676
07-05-2020, 07:09 AM
Last Post by jomo
Views 1,393
23-01-2020, 06:11 PM
Last Post by reco2k
Replies 26
Views 2,490
09-09-2019, 01:04 PM
Last Post by Stoney
Views 1,453
12-07-2019, 11:15 AM
Last Post by sprinter2012
Views 503
04-07-2019, 03:35 PM
Views 1,420
29-03-2019, 07:09 PM
Last Post by Fry-Up
Replies 24
Views 2,763
11-06-2018, 12:49 PM
Last Post by Sam B
Views 879
20-05-2018, 10:16 AM
Replies 23
Views 1,769
17-03-2018, 07:01 PM
Last Post by lexynik
