Braking
Braking
I suggest you try hard braking from speed (safely, of course) in several different places and see it is always does it, or if it's just in those couple of locations. The fact it goes both left and right would suggest maybe the road is guiding it!
bad break lines, mine did that before i changed them, had my breaks off and checked and no problems, changed the lines and not had it since, i had put new dicks and pads on and checked out all ok
jay_russell bad break lines, mine did that before i changed them, had my breaks off and checked and no problems, changed the lines and not had it since, i had put new dicks and pads on and checked out all ok
^^^ lol
no mate one of my lines was all messed up in side were the rubber had split and was blocking it, hence it was pulling to one side, had the break off and checked and there was no rust or problems with it, removed the line and found it was half blocked by the rubber and was no letting a propper flow
