JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Modifications & Tuning HID headlights
HID headlights
HID headlights
Barry
30-11-2020, 07:00 PM
posty Yes mate that is the kit, same one that I have.
Will take you a maximum of 10 minutes to fit!
Are 8000k white with a blue tint? like LED torches?
Barry
30-11-2020, 07:00 PM #11
30-11-2020, 07:09 PM
Please don't fit HID lights into non HID reflector housings. It makes you a massive wanker as the beam pattern is wrong and you blind everyone else coming towards you. If you want HID's either swap in some IS300 headlights or do a projector install.
30-11-2020, 07:09 PM #12
posty
30-11-2020, 07:11 PM
el_bandido Please don't fit HID lights into non HID reflector housings. It makes you a massive wanker as the beam pattern is wrong and you blind everyone else coming towards you. If you want HID's either swap in some IS300 headlights or do a projector install.
Is it hard work hating everything?
posty
30-11-2020, 07:11 PM #13
30-11-2020, 07:12 PM
No, people who blind me while I'm driving make it very easy.
30-11-2020, 07:12 PM #14
posty
30-11-2020, 07:13 PM
Barry Are 8000k white with a blue tint? like LED torches?
Yes mate, a slight blue tint but not too much.
posty
30-11-2020, 07:13 PM #15
Jon
01-12-2020, 05:31 AM
el_bandido If you want HID's either swap in some IS300 headlights or do a projector install.
i thought IS300 headlights don't fit?
Jon
01-12-2020, 05:31 AM #16
01-12-2020, 07:11 AM
with some very slight modification, they do.
01-12-2020, 07:11 AM #17
Multics
01-12-2020, 07:29 AM
I'm with Bandido on this one. HID kits in reflectors is a bad idea due to incorrect beam pattern and light bleeding above the cutoff point. On top of that most people go for 6000k which makes matters worse. I'm a massive fan of headlight modifications, done projector retrofits on all my cars and I'm sure that most people will prefer the light output and looks of a proper retrofit vs a nasty 6000k hid kit. I'm more than happy to help if someone wants to go that route. It's quite easy to do actually.
Lexus IS 250 SE-L
Multics
01-12-2020, 07:29 AM #18
Lexus IS 250 SE-L
posty
01-12-2020, 05:04 PM
Im not starting an argument here, but if the beam patten is that bad how have I passed the last 2 MOT's with my 8k HID kit? I may be wrong but don't they check that?
posty
01-12-2020, 05:04 PM #19
01-12-2020, 05:16 PM
I don't actually think aftermarket HID kits running in halogen housings are even legal for road use in the UK.
Links: http://www.phoenixautobulbs.co.uk/tp/hid...tion-2012/
see the FAQ on hids4u.co.uk http://www.hids4u.co.uk/faqs.html
also right at the bottom of hidsdirect.co.uk terms and conditions: http://www.hids-direct.co.uk/terms-conditions/
edit: I'm not trying to argue either, I just think that if you want HID's, you should do it properly.
Edited 12-01-2013, 09:07 PM by el_bandido.
01-12-2020, 05:16 PM #20
Views 595
19-01-2025, 01:28 PM
Last Post by cjoseph
Views 560
21-04-2022, 05:35 AM
Last Post by lexusdaydreaming
Views 1,803
28-03-2020, 04:47 PM
Views 1,361
13-10-2019, 08:43 PM
Views 1,823
15-04-2019, 04:49 AM
Last Post by James S
Replies 18
Views 2,399
03-02-2019, 09:16 PM
Last Post by DTD
Views 1,754
22-11-2018, 10:25 PM
Last Post by D6NGR..
Replies 27
Views 3,196
21-07-2018, 08:36 PM
Last Post by Phil01
Replies 40
Views 4,001
03-09-2017, 02:59 PM
