JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Brakes & Suspension Vibrating noise while driving
18-10-2019, 07:21 AM
Buy from the link in this thread mate Smile
18-10-2019, 07:21 AM #11
18-10-2019, 07:50 AM
What you need to do is get the car up on some ramps (i.e. in the air, with the weight on the wheels) and then have a good going over all the suspension and drive components (propshaft, driveshafts, cv joints, bearings, bushes, wishbones etc) til you can find something that moves around when it shouldn't!
18-10-2019, 07:50 AM #12
18-10-2019, 10:01 AM
Toxo - are you in the MK area mate?
18-10-2019, 10:01 AM #13
18-10-2019, 10:10 AM
Yessir, I am.
18-10-2019, 10:10 AM #14
Yessir, I am.
18-10-2019, 10:20 AM
If you've got access to a ramp, can I blag some time for beer tokens?
18-10-2019, 10:20 AM #15
18-10-2019, 10:22 AM
I haven't unfortunately, I do everything on jacks and axle stands!
I'm happy to take a look at it though, if you like. Am fairly familiar with IS200 suspension, including eliminating rattles from it :lol:
18-10-2019, 10:22 AM #16
18-10-2019, 10:56 AM
toxo I haven't unfortunately, I do everything on jacks and axle stands!
You've had enough practice.
18-10-2019, 10:56 AM #17
rob
18-10-2019, 02:09 PM
try this: and this goes for other members also.....
engine running, car still, shake steering wheel left/right. do you get a knock sound?
rob
18-10-2019, 02:09 PM #18
18-10-2019, 07:23 PM
I wouldn't say I get a knock sound, but it is a bit clunky when switching directions using the method described above.
18-10-2019, 07:23 PM #19
rob
21-10-2019, 09:05 AM
then the plastic universal joint that allows you to move the steering wheel up/down is worn. No replacement parts are available, toyota only supply a complete inner steering shaft at about £400.
you can remove the column in 20 mins.
rob
21-10-2019, 09:05 AM #20
Views 645
24-07-2019, 10:31 AM
Last Post by speedfreek
