JapCarForum Club Sponsor SpeedView Displays Seeking Test Pilots (discount for photos)
speedview
06-11-2019, 06:42 PM
You know the answer to that 2tongues! Wink
Project car and a runabout is a common scenario. I can pop a 2nd fitting kit (screen/cable/wire clips/mounting) into the box free of charge if you fancy an install in both.
Tango - I'd start at the radio head unit, VSS is often on the ISO plug. Else behind instruments, or as a last resort from the ABS ECU. If you're lucky, all the required wires will be accessible from the footwell so you can sneak the power/signal cable between the dash and the windscreen, and make all the connections underneath without too much dismantling.
If you fancy a second set of eyes, feel free to forward any wiring diagrams to the email address above and I'll try find the relevant wires.
Toxo - I've got the MkII MR2 pretty covered via the MR2OC, but still have an opening for MkI/MkIII info.
MkIII Fiesta? Sure - the offer stands for anything! I suspect "daily drivers" like Fiestas (probably the MkIV more than the MkIII mind) could well end up as my bread and butter sales that actually pay the bills, with the "halo cars" and any "classic cars" more just for the fun of it. Drop us a line if you fancy it anyhow. Smile
speedview
06-11-2019, 06:42 PM #11
mplavery
06-11-2019, 08:23 PM
I knew Andrew would get one lol, So if you put one of these in your Zed that will be 3 speed indicators in your car lol
although I'm not going to buy one now as my car is off the road these do look like a good bit of kit and will be looking to get one in the future for sure
2nd BEST IN SHOW (JAE 2011)
3rd BEST MODIFIED (JAE 2011)
[/COLOR]
[/COLOR]
mplavery
06-11-2019, 08:23 PM #12
[/COLOR]
[/COLOR]
08-11-2019, 07:19 PM
Mine arrived today looks to be a great piece of kit will have a go at fitting it to the stagea this weekend
Do you know what the optimum viewing angle is thinking about mounting on the room of the car projecting onto the top of the screen instead of the bottom.....
08-11-2019, 07:19 PM #13
speedview
08-11-2019, 07:42 PM
Good good Smile
You're not going to see the reflection in the screen if its roof-mounted I'm afraid. Cool idea, but the screen rakes the wrong way: You look forwards at the screen. Screen is at approx 45 degrees. If the screen were a mirror, you'd just see the dashboard. mostly you see through glass, but there is some reflection of the dashboard, and that's what the SpeedView is using.
You can have the image projected higher up on the windscreen if you like by moving the display further away from the base of the screen (move it towards you) but eventually you'll run out of dashboard!
Why not power up the display and wave it around a while first?
The centre of the ciggy lighter is (+)ve and the outside is (-)ve. If you have a phone charger or similar kicking about you can wrap some of the red wire around the 'pin' on the end and some of the black wire around the body then carefully slide it in for a quick connection.
You'll soon see where looks good. On Land-Rovers and classics with a really vertical screen the display is best tilted towards the windscreen slightly, but on modern stuff near-horizontal is ideal.
Don't tilt it towards you too much otherwise you might see the projection and the reflection at the same time - this can be annoying as the projection is much brighter than the reflection!
speedview
08-11-2019, 07:42 PM #14
Good good Smile
08-11-2019, 07:48 PM
I'll have a play will get it wired up sitting on the seat lol then point it at the screen see what happens lol I'll find a way lol....
I'm assuming I can find a feed on my emanaage blue which will make life easier as that sitting staring at me whilst driving lol
08-11-2019, 07:48 PM #15
Kevpr
10-11-2019, 09:18 AM
I'll take one of these for the Tezzy as when I eventually fit my TRD clocks and convert it to mph the speedo needle is hardly going to move! I could do with a nice clear readout.
Do you need a guide for an Altezza / IS200 ?
Kevpr
10-11-2019, 09:18 AM #16
speedview
10-11-2019, 12:41 PM
Hi Kevpr,
jay_russell and sparkystav should have the IS200/Altezza guide covered. (I assume they're both the same as far as wiring goes?)
How far around do the TRD clocks run?
speedview
10-11-2019, 12:41 PM #17
Hi Kevpr,
Kevpr
10-11-2019, 01:07 PM
Yeah, wiring should be the same.
This is what my dials look like:
[Image: 2959yte.jpg]
When they have been converted to mph there is not a lot of movement in the needle, but plenty of room for inaccuracy.
Kevpr
10-11-2019, 01:07 PM #18
10-11-2019, 01:18 PM
That's not so bad, some of the TRD dials go up to 300kph!!
10-11-2019, 01:18 PM #19
speedview
10-11-2019, 01:40 PM
Same problem as the Porsche crowd - one needle width is 5+ mph and its impossible to read. :-o
Love how they always show 20/40/60 as the big numbers too, rather than 30/50/70. At least the smaller ticks are 5 mph not 2 mph. (my old MX5 clocks would have '20' then 9 little marks and '40' so it wasn't easy to ID 28 or 32 if that makes sense?)
Does anybody do a converter/set of dials that count 20-40-60-80-100-plenty? (big spaces from 0-100 mph then squash everything over that into a little bit) The opposite of the tachos that run a scrunched up first part:
http://www.demon-tweeks.co.uk/performanc...tachometer
speedview
10-11-2019, 01:40 PM #20
