JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security LFA style cluster interesting
el_gencer
05-12-2019, 10:06 AM
This post got me thinking, so i did some research. For around £12 off flea-bay you can get an ODBII bluetooth interface. Then for £19 you can purchase Dash Command from Android Market or iTunes. Once installed you can then install the LFA skin to get the dash dials.
http://www.palmerperformance.com/product.../index.php
http://www.dashxl.net/search.php?searchKeyword=Lexus
I'm currently trying to figure out how i'm going to implement this into my IS200. Any suggestions ?
el_gencer
05-12-2019, 10:06 AM #11
05-12-2019, 10:12 AM
Android tablet pc off eBay then mate sounds like the best option.
05-12-2019, 10:12 AM #12
05-12-2019, 10:16 AM
Or you could get your OBD adaptor and spend £3 on Torque... I'm sure there's an LFA skin for it somewhere and it's a lot more useful!
05-12-2019, 10:16 AM #13
el_gencer
05-12-2019, 10:18 AM
It's more of a "where do i mount it" thing. In the dashboard ? Where the radio goes ? Or ala Nissan GTR style on the dash tray ?
el_gencer
05-12-2019, 10:18 AM #14
05-12-2019, 10:19 AM
I've seen someone do that before in an Integra with an HKS CAMP. Replaced the centre of the dashboard with a screen, and kept the petrol and water temp gauges either side in place.
I'll see if I can find a photo.
05-12-2019, 10:19 AM #15
05-12-2019, 01:29 PM
toxo Or you could get your OBD adaptor and spend £3 on Torque... I'm sure there's an LFA skin for it somewhere and it's a lot more useful!
I created a Lexus dial skin for Torque on my own then realised I was somewhat lacking in the arty area :lol:
05-12-2019, 01:29 PM #16
northernmonkey
06-02-2020, 09:05 AM
toxo,
You seem to know Ian. I've been having a few convo's via email with him, what a helpful chap! I'm struggling at the mo though, dash command seems to remember my bluetooth settings (I'm rebooting and crashing the tablet on every start up and shut down, it's flash memory) but Torque won't.
Ian seems convinced it's because of the android settings but I don't see how it can be if dash command remembers it? I'm having to manually enter the pass key in torque.
I'm going to look at a bluetooth auto pair, but it would be lovely if torque worked properly (bluetooth) like dash command, be even better if it fired up in fast mode and then had the option to go back to slow if needed.
I really want to use torque, it's so much faster etc but for me, there's just a couple of irritations with it so far!
northernmonkey
06-02-2020, 09:05 AM #17
toxo,
06-02-2020, 09:08 AM
Yeah I do, I used to work with him and lived with his brother for a bit! You're right, he is a sound bloke.
Have a poke around with a file manager on your android device and pull the .torque folder off the filesystem. That's where it stores the settings. You should be able to open (some) of the files in a text editor to see what settings it's storing. That said, the passkey may be encrypted.
If you close and reopen torque does it remember the settings? i.e. does it only forget them on a full reboot?
Edited 19-03-2012, 12:57 PM by toxo.
06-02-2020, 09:08 AM #18
06-02-2020, 09:11 AM
Also I presume you've asked the question on the Torque forums?
06-02-2020, 09:11 AM #19
northernmonkey
06-02-2020, 03:55 PM
The thing is, it's now built into the car, so to plug anything in is a major hassle. Everything has to be done over wifi.
I've not asked on torque forums because to be honest, Ian has always got back to me very quick.
The mad thing is now, it'll connect to dash command no problem, but it would appear the problem lies within the android os itself. I have had it connect to torque so i know it works, but all i'm getting in the android os settings now is 'paired, but not connected'
Nothing i do will sort it, I've deleted the device, restarted etc etc, it's the same thing.
I'm gonna try with my other tablet, and if it works, delete everything and start again (over wifi!) in the car. (or i could just leave the very slow dash command as the default gauges, it's pretty, but flaming slow!
northernmonkey
06-02-2020, 03:55 PM #20
Views 920
19-03-2021, 07:13 AM
