Pages (58): Previous 125 26 27 28 2958 Next
20-02-2018, 07:09 PM
well that picture is just the mechanic holding it in place. its all bolted on now. its a little bit more space than before. the picture makes the space look small. People from the company that does ceramic coating were in today and he said ceramic coating the turbo and radiator will solve cooling issues if there is any so im going that route if there is cooling problems. but seriously the picture makes the space look a lot smaller than what it is
20-02-2018, 07:09 PM #261
20-02-2018, 07:11 PM
when i bought the car the radiator was closer to the turbo before and marcus said he didnt have any heating up issues only problem he had was the engine heated up due to the water pump failing.
20-02-2018, 07:11 PM #262
20-02-2018, 08:27 PM
you can buy turbo jackets which would solve any problems..
20-02-2018, 08:27 PM #263
20-02-2018, 11:42 PM
yeah i could do that but getting a good deal on cermaic coating so i going to go ahead with that.
20-02-2018, 11:42 PM #264
21-02-2018, 06:16 AM
I realise the turbo was closer in Marcus's original setup, but with the greatest respect to Marcus, that looked pretty tight there too.
The thing with coating/jackets for turbos is that you're going to make them run even hotter then.
21-02-2018, 06:16 AM #265
21-02-2018, 06:27 AM
steviewevie I realise the turbo was closer in Marcus's original setup, but with the greatest respect to Marcus, that looked pretty tight there too.
but the heats kep inside the turbo not to the outside
21-02-2018, 06:27 AM #266
21-02-2018, 06:34 AM
Are the jackets also used to reduce turbo laggggg?
21-02-2018, 06:34 AM #267
21-02-2018, 06:42 AM
Sparkystav but the heats kep inside the turbo not to the outside
That's what I mean though, the turbo runs even hotter. So when you turn the engine off the oil cooks inside the turbo for longer etc. I just can't see it as a good thing. I imagine it shortens the life of the turbo. I could be totally wrong of course !
Edited 04-04-2010, 10:37 AM by steviewevie.
21-02-2018, 06:42 AM #268
21-02-2018, 06:57 AM
steviewevie That's what I mean though, the turbo runs even hotter. So when you turn the engine off the oil cooks inside the turbo for longer etc. I just can't see it as a good thing. I imagine it shortens the life of the turbo. I could be totally wrong of course !
Solved with a turbo timer?
21-02-2018, 06:57 AM #269
21-02-2018, 07:01 AM
2tongues Solved with a turbo timer?
The turbo is still running hotter all the time than it would without the jacket/coating though.
Surely if, for example, your engine ran hotter *all* the time then it would shorten its life ?
21-02-2018, 07:01 AM #270
Views 3,362
Views 3,867
Views 13,691
Views 6,753
Views 34,326
Views 5,016
Views 10,313
Views 1,589
Views 1,915
Views 2,755
