JapCarForum Cars, Cars, Cars! Help Topics - Submit Your Help For Other Members! passenger windows wont go up or down.
Pages (3): Previous 1 2 3
daveb948576
31-01-2021, 04:22 PM
Earthing the pwl wire on the drivers door made no change to how it was before. Can I check the wires at the relay for earths and lives to make sure I have them? Which terminals though.
daveb948576
31-01-2021, 04:22 PM #21
daveb948576
31-01-2021, 05:54 PM
when bridging these two terminals the windows work exactly as they are supposed to, including the locking button on the drivers door, i think i'll just bridge those two permanently, the bottom right terminal is a positive and so is the upper most top one, one of those must 12v+ from the ignition so i'll put the wire on that and be done with it, at a guess i would say the fuse box was broken.
[Image: img20130314201922.jpg]
daveb948576
31-01-2021, 05:54 PM #22
daveb948576
31-01-2021, 06:51 PM
for some reason the bottom left terminal is not earthed at all to anything which it should be (i think) so somewhere between that terminal and earth to ground/body/battery the wire or circuit board inside the fuse box is broken, i could either take apart the fuse box to find the circuit and get lost in a maze of bits and bobs/wires/chips or who knows what or i can just earth that terminal by sticking a length of wire to ground it on the back of that spade terminal so it has a new earth and the relay would click when the ignition was turned on and my windows would work.
daveb948576
31-01-2021, 06:51 PM #23
