JapCarForum General Discussions The JCF Lounge Av guys please come in here.
Mikey
27-04-2021, 08:56 AM
ok cheers Toxo so it would be like the one with the rj45 wall plates and cat5e cable
Mikey
27-04-2021, 08:56 AM #21
Mikey
29-04-2021, 12:55 PM
ok next mission
so im now putting the connectors on the wiring, but which order do the wires go in im just checking to be certain before i go ahead and crimp the dam, things there is 2 ways of wiring the faceplates up A or B i will make sure before i crimp that the faceplates are one or the other
i was going to follow this would this be correct
[Image: cat5_color.gif]
also number one pin is like this
[Image: RJ-45-Wiring-Diagram.png]
Mike
Mikey
29-04-2021, 12:55 PM #22
ok next mission
Mike
29-04-2021, 01:56 PM
Use wiring style B - no one uses A. It doesn't matter which you use as long as it's the same at both ends, but most wall modules will have coloured markings on them for B. Your pin numbers are right. So if you have the plastic plug in your hand, with the wire coming out of the bottom and the metal pins facing you, they are numbered 1-8 left to right.
29-04-2021, 01:56 PM #23
ZAIS200
01-05-2021, 06:33 AM
toxo Use wiring style B - no one uses A. It doesn't matter which you use as long as it's the same at both ends, but most wall modules will have coloured markings on them for B. Your pin numbers are right. So if you have the plastic plug in your hand, with the wire coming out of the bottom and the metal pins facing you, they are numbered 1-8 left to right.
Yip Toxo Exactly right, most conventions use B but in theory it doesn't matter what colour coding you use as long as its exactly the same on the other end
ZAIS200
01-05-2021, 06:33 AM #24
Mikey
01-05-2021, 06:51 AM
thanks guys got this all up and running i now have interwebz in my man cave / bar whooooooo
Mikey
01-05-2021, 06:51 AM #25
01-05-2021, 06:54 AM
Well done. You'll be after my job next...
01-05-2021, 06:54 AM #26
01-05-2021, 07:05 AM
toxo Well done. You'll be after my job next...
You can have mine lol.
01-05-2021, 07:05 AM #27
01-05-2021, 07:08 AM
Good work mate.
01-05-2021, 07:08 AM #28
Good work mate.
ZAIS200
01-05-2021, 07:16 AM
Awesome now let us see your man cave with oily bits lying all over, and a keg in the background...lolBig GriniscoStu:
ZAIS200
01-05-2021, 07:16 AM #29
Mikey
01-05-2021, 09:19 AM
Cheers guys
ZAIS200 its still a work in progress, i have got a few pics from a few years ago will get some more when i have a decent camera/phone (broke my s3)
This is what it was like when i brought the house, the wood paneling was not around the bar it was bare breeze block so i lathed & paneled it
[Image: 20052011280.jpg]
i cut the top off the bar as i didnt like it, it was getting in the way height wise, also removed the shelving off the wall to create more room behind the bar counter top
[Image: 20052011282.jpg]
then gave the wood paneling on the front of the bar a stain but needs another coat
[Image: 21052011284.jpg]
these are the only pics i have at the moment but other work has been completed
all walls painted cream/magnolia as i didnt like the brown
got a projector off a mate, made a screen for it and fitted it
fitted and wired 2x 6ft strip lights in the top of the apex roof lights the room up quite well
lights around the front of the bar RGB colour changing with remote
just doing some work in the garden atm building a little wall to split the garden up a bit then going to lay a patio and get the Mancave renderd, busy busy busy
Mikey
01-05-2021, 09:19 AM #30
Cheers guys
Views 510
14-06-2021, 06:10 PM
Replies 74
Views 9,704
19-09-2019, 07:24 AM
Last Post by johnyboy1976
Replies 23
Views 3,216
11-02-2019, 01:43 PM
Views 1,784
22-08-2018, 05:49 PM
Last Post by Chris
Views 2,406
01-07-2018, 01:25 PM
Views 626
05-06-2018, 06:46 AM
Replies 107
Views 9,620
30-03-2018, 06:28 PM
Last Post by John G
Replies 22
Views 2,418
23-03-2018, 07:43 PM
