JapCarForum Trade Area Selling TTE Supercharger pulley 160mm
Pages (3): Previous 1 2 3
Rolex
06-02-2022, 08:08 PM
from what I understand to run a 145 or 160 mm pulley you need the 1zzfe injectors and one of patricks black boxes.
Rolex
06-02-2022, 08:08 PM #21
daveo
06-02-2022, 08:10 PM
cheers rolex, ive a blackbox. do you know anyone with that setup that i could chat to ??
daveo
06-02-2022, 08:10 PM #22
Rolex
10-02-2022, 03:43 PM
CammyGrievy had the 160mm pulley on his IS200 and was pulling 235 bhp. Here his IS200 for sale on Driftworks before he sold it. https://www.driftworks.com/forum/drift-c...arged.html
Also I believe Dimitries is also running a 160mm pulley but he opted for a piggy back instead.
Rolex
10-02-2022, 03:43 PM #23
phaebo
11-02-2022, 08:28 AM
I used to run a 145 mm pulley with 1zzfe green injectors and patricks blackbox. This runs great no problems. But then i tried a 155 mm with the 1 zzfe injectors but that is running lean. Those are to small and cant give enough fuel.
Now i have a 155 mm pulley with 2zzge injectors 310 cc and patrick blackbox but i keep getting trouble codes that it is running too rich.
So the 1zzfe injectors and 145 mm pulley are the biggest you can run with the patrick blackbox.
You will need a piggyback ecu or something to manage the injectors.
phaebo
11-02-2022, 08:28 AM #24
phaebo
11-02-2022, 08:32 AM
The 2zzge injectors will run good till 4000 rpm but above they are overfueling.
And you will get trouble codes that it is running too rich
phaebo
11-02-2022, 08:32 AM #25
daveo
11-02-2022, 11:34 AM
PHAEBO.......finally someone who knows what they are talking about Smile thanks for that info. have her running anyhow. made up a 140mm pully instead of the 160mm i used. car is gone away for fuel pressure reg and to be dynod
daveo
11-02-2022, 11:34 AM #26
phaebo
11-02-2022, 02:50 PM
140 mm pulley is about the biggest you can safely go with the oem injectors. It will give you 0,4- 0,45 bar pressure.
The 145 mm pulley gives 0,5 bar near the rdv limit
The 155 i have pushes 0,6 bar near the rev limit. Those are just some numbers to give you an idea
phaebo
11-02-2022, 02:50 PM #27
196
24-04-2022, 04:41 PM
Daveo what did dyno say? Bhp?
lexusdaydreaming
24-04-2022, 04:41 PM #28
196
10-05-2022, 05:20 PM
upgraded pully and he was only getting 235 bhp? surley thats not right?
lexusdaydreaming
10-05-2022, 05:20 PM #29
Views 901
15-02-2025, 09:31 AM
Replies 117
Views 8,229
26-01-2025, 04:51 PM
Last Post by MANCBLUE83
Views 426
18-06-2023, 10:42 AM
Views 836
05-05-2023, 04:21 AM
Replies 33
Views 2,475
14-03-2023, 05:03 PM
Last Post by cjoseph
Views 704
28-08-2022, 06:32 AM
Last Post by Lance79
Views 491
14-08-2022, 02:05 PM
Views 1,629
14-04-2022, 06:00 PM
Last Post by MajorT
