only getting hot air
What should I be looking for with the pipes? My heating has been like this for ages. No water coolant loss or anything
Under the steering column on the left
There two thin ally pipes mine was leaking where it goes into the heater matrix this is what I call it lexus dont tho mine didnt seem to loose any water but the amount it was leaking was enough to upset things till it propper let go it steamed up the window so much I couldnt hardly see ha ha ha was ****** dangerous
Cheers mate. I'll check it out. Will I need to remove the panel under the steering wheel?
if car isnt loosing coolant, check actuators (two black boxes in 3rd picture), because they tend to fail too...
turn ignition to ON and change temperature settings, you should see one of them moving its arm therefore moving flaps inside the unit to change air flow trough heater core and thus giving you warm air...
lex2oos if car isnt loosing coolant, check actuators (two black boxes in 3rd picture), because they tend to fail too...
You can frig the flap basically so it avoids the interior radiator
Well I've been trying to sort this problem out again today.
I've changed the two servo motor things that control the temperature and the direction of flow.
Now I can only get very cold air or very hot air to the windscreen . And side vents. But nothing to your feet or warm air.
Any ideas folks ?????
