JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Supercharging & Turbo Modifications HKS FCD install
HKS FCD install
HKS FCD install
Pages (3): Previous 1 2 3
14-04-2018, 04:04 PM
you do not need an uprated fuel pump............the fuel pump only supply's what the injectors ask for...........so lets just say you have a fuel pump that supplys a max 1 lrt per min and the injectors ask for 400mlrts per min.......fuel pump is fine...........so you go away and supercharge it now the injectors ask for 650mlrts per min the fuel pump is still fine...what i'm trying to say is the standard fuel pump can handle a hell of a lot more than what the injectors ask for when you charge it.......
as for the air temp sensor i extended the wires on mine and drilled a hole approx an inch from my cone filter(in the silicone induction pipe) and fitted it in their..
most of the chargers flat spots can be solved by playing with the fcd settings...
14-04-2018, 04:04 PM #21
Views 932
03-12-2021, 03:27 PM
Replies 55
Views 5,222
11-07-2019, 11:31 AM
Last Post by Stoney
Views 1,897
16-01-2019, 06:23 PM
