JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza maf sencor help
maf sencor help
maf sencor help
Pages (3): Previous 1 2 3
29-09-2018, 05:40 PM
no it started a week ago then reset the faults for the o2 sensor after i changed it. the yesterday it started again and cant get over 3000 rmp before it fells like it's running on kanagroo juice
29-09-2018, 05:40 PM #21
29-09-2018, 05:45 PM
It sounds like whatever uprated MAP sensor you have isn't working properly, and/or the piggyback ECU (what do you have ?) isn't working properly (bad connection ? fault ?). So instead of lying to the stock ECU, the stock ECU is seeing too much boost and so the car is going into limp mode.
29-09-2018, 05:45 PM #22
29-09-2018, 06:19 PM
running a blue. but will talk to my mapper tomorrow as some things have not been right since i got it back. my halo eyes on one side have stopped working and one of the map lights is the same. and i have changed both o2 sensors and still have a fault on bank1 sensor 1
29-09-2018, 06:19 PM #23
29-09-2018, 07:45 PM
ok, so if it's an e-Manage blue, it hasn't got a built-in uprated MAP sensor. So you must have a separate one somewhere ? I've got GReddy's own uprated MAP sensor attached to my e-Manage Ultimate.
29-09-2018, 07:45 PM #24
Have you got an AFR gauge so you can see what's going on there ?
29-09-2018, 07:45 PM #25
30-09-2018, 02:27 AM
yer but have to connect it up. all in place just need to fit the wire. waited till i changed the o2 sensor before i did it
30-09-2018, 02:27 AM #26
30-09-2018, 07:41 AM
I strongly recommend getting the AFR gauge connected up ASAP. Mine has been absolutely invaluable, especially when anything weird happens, to help me see what's going on.
Going back to your mapper sounds like a good plan to me. Are you planning to swap out the e-Manage blue for something with more capability ? e.g. an Ultimate or another piggyback ECU ?
30-09-2018, 07:41 AM #27
