JapCarForum Cars, Cars, Cars! Car Audio/Video/Electronics/Security Generic Push Start Button & Proximity Entrance
Pages (8): Previous 1 2 3 4 5 … 8 Next
22-12-2018, 05:20 AM
looks like alot of work but I think its worth it for the end result
22-12-2018, 05:20 AM #21
22-12-2018, 05:36 AM
Nice work Rabs Smile
@asi, Rabs has done his with a clifford!
Rabster Ok well we have success
Rabster IS200 2002 turbo with CLifford Avantguard 5.5 Security System
22-12-2018, 05:36 AM #22
22-12-2018, 07:09 AM
The push start button will work with any car. The standard lexus immobiliser will get in the way but we are working on this as no one will want to loose security
22-12-2018, 07:09 AM #23
Carpediem
22-12-2018, 07:36 AM
could you not bypass the issue by getting an is220 security module or is it all inbuilt to the ecu?
they all have push button start and proximity sensor entrance anyway so would cut back on alot fo the issues your having? and keep it pretty oem?
Carpediem
22-12-2018, 07:36 AM #24
22-12-2018, 07:56 AM
I'm not sure if it would work but I'm guessing getting the full OEM Toyota kit would be seriously expensive...........
How did the my.is guys get around the immobiliser or have they just put a key in the steering column like before?
22-12-2018, 07:56 AM #25
Carpediem
22-12-2018, 08:05 AM
surely theres an aftermarket version? or is that jsut alarms ystems and not imobilisers?
i dont much about this but like to feel included Smile
Carpediem
22-12-2018, 08:05 AM #26
22-12-2018, 08:29 AM
Carpediem could you not bypass the issue by getting an is220 security module or is it all inbuilt to the ecu?
i have spent many months looking over this and there is no easy way to combine the system from a 200 to a 220.
plus the cost for the modules form a breakers outweighs the cost of doing the work for example
this system that is after market is universal so not limited to the one brand of car, i will be retrofitting to other makes also....
the push start works with any brand of car you just have to disable the factory immobiliser but if you add your own immobiliser to this system then you are laughing this can be done using relays and being well hidden in the car wiring loom to deter thief's or you can even buy a immobiliser harness to add in...
As for the proximity this works in conjunction with the push start or as a unit on its own, in my case it will be used to control the entrance to the car via an after market alarm for me this will be done using a relay and 2 diodes (full details will be posted upon completion...)
once installed there is no reason to think this unit isnt OEM as if installed correctly and not rushed it will be the dogs nutz
22-12-2018, 08:29 AM #27
22-12-2018, 08:31 AM
parthiban I'm not sure if it would work but I'm guessing getting the full OEM Toyota kit would be seriously expensive...........
the genuine system is mega expensive and not easily linkable to older generation cars
The my.is guys have removed the steering column lock and then sacrificed a key removed the transponder and stuck to the transponder RX.
i should think they have installed a Immobiliser system not sure if the proximity comes with anything will have to check....
22-12-2018, 08:31 AM #28
22-12-2018, 08:48 AM
What does an immobiliser actually do? Surely the proximity sensor is itself an immobiliser as the engine won't start without the fob nearby?
22-12-2018, 08:48 AM #29
22-12-2018, 08:55 AM
the proximity will allow you entrance to the car so in effect yes it will act as a kind of immobiliser in the fact you still nee to get into the car
the immobiliser stops the engine form cranking some models also stop the acc from turning on
22-12-2018, 08:55 AM #30
Views 927
30-03-2022, 09:01 AM
Last Post by Millo73
Views 3,172
25-12-2018, 06:56 PM
