Pages (58): Previous 128 29 30 31 3258 Next
28-02-2018, 04:34 AM
Asi well insurance is going to be under the garages traders policy so cool that way.
but if you own the car, and/or dont work for the garage then its a bit dodgy isnt it?
28-02-2018, 04:34 AM #291
lexynik
Unregistered
28-02-2018, 07:20 AM
cool-at least it should be done quite soon tho - i would think covering it on the traders insurance is the simplest way too - if it came to it eventually you can rego it to them-its certainly going to showcase their work as well as yours-one more name on a logbook wont matter to a car like this as long as you have cover-plus i would imagine asi is classed as working there now due to the many hours a week he does there on this one Wink
lexynik
28-02-2018, 07:20 AM #292
28-02-2018, 08:27 AM
Another thought on the cooling side of things would be to use Water Wetter, quite a few racing cars use it as it brings down the temps! WATER WETTER LINK FOR OPIE OILS :thumbup1:
28-02-2018, 08:27 AM #293
28-02-2018, 08:30 AM
Bandit Another thought on the cooling side of things would be to use Water Wetter, quite a few racing cars use it as it brings down the temps! WATER WETTER LINK FOR OPIE OILS :thumbup1:
Prius owners also use it in the USA to get engine temps up faster - therefore metter MPG.
28-02-2018, 08:30 AM #294
28-02-2018, 11:16 AM
Sparkystav but if you own the car, and/or dont work for the garage then its a bit dodgy isnt it?
Well I suppose it is. Which company are you with stav. Will start getting quotes next week
28-02-2018, 11:16 AM #295
28-02-2018, 11:21 AM
I need to wait till the car is up and running to see if the cooling should be looked at or not but hopefully shouldn't need to as everything is getting cermaic Coated
28-02-2018, 11:21 AM #296
28-02-2018, 11:48 AM
yes and no it depends on how the garage do it....yes you can add family and friends to a traders policy but the car must be named on the policy...
reason they might void the claim if the car is owened by you and not a customer..
28-02-2018, 11:48 AM #297
28-02-2018, 12:18 PM
it all depends on the type of policy you have
28-02-2018, 12:18 PM #298
Marcus_1UZ
01-03-2018, 01:06 PM
Asi when Marcus was running it he said the turbo didnt heat up so i dont see it heating up now as theres more room between the radiator and the turbo itself. if it does have any problems then cermaic coating will help.
Hi all not been around, for long time,
When the car was up and running with the turbo, it use to over heat, and that was down to it leaning out!! "IE" to much boost and not the right fueling= lean, it did not over heat cos of the turbo!! , when i did away with the boost pipe from the turbo! the car would run all day long and the heating was ok, dont for get he did drive the car back! and it was ok,
i did say at the time all he had to do was get the fueling right and the car would boost all day long with out overheating .
Marcus_1UZ
01-03-2018, 01:06 PM #299
01-03-2018, 01:20 PM
Hey long while no see hope your doing alright Marcus:thumbup1:
01-03-2018, 01:20 PM #300
 5 Guest(s)
 5 Guest(s)
Views 3,082
Views 3,464
Views 12,605
Views 6,229
Views 32,738
Views 4,568
Views 9,719
Views 1,467
Views 1,785
Views 2,621
