JapCarForum General Discussions The JCF Lounge Av guys please come in here.
ZAIS200
01-05-2021, 09:59 AM
#31
Dude that is awesome, it looks really spacious, Looks really good, keep up the good work
ZAIS200
01-05-2021, 09:59 AM #31
Mikey
01-05-2021, 12:36 PM
#32
Cheers mate it is quite large i forget the actual size i will get some more snaps when i can of what it looks like now.
@ toxo
just a quick one mate what would i have to do to get wireless down there as this connection is comming off a virgin wireless router, i dout just hooking up a wireless router the other end will work ?
Mikey
01-05-2021, 12:36 PM #32
@ toxo
01-05-2021, 12:38 PM
#33
You don't want a router as routers make connections between 2 different networks and you want all your stuff in your house and your shed on the same network. You want a wireless access point.
Some routers can just be switched into access point mode through the web interface, but usually the ones the ISPs give you don't allow that sort of thing.
01-05-2021, 12:38 PM #33
Mikey
#34
toxo Well done. You'll be after my job next...
can i use your job title on my CV now LOL
Mikey
01-05-2021, 12:38 PM #34
Mikey
01-05-2021, 12:39 PM
#35
Cheers for that quick response, so i will look for a wireless access point later on
Cheers bro
Mikey
01-05-2021, 12:39 PM #35
Cheers bro
02-05-2021, 07:31 AM
#36
I specified one of these for a job at a remote office recently. Set it up as a standalone access point, with the same name, security type, and passphrase as your current wifi network and job done! 2 yr manufacturer warranty too.
http://www.ebuyer.com/259812-tp-link-wir...tl-wa701nd
02-05-2021, 07:31 AM #36
ZAIS200
02-05-2021, 08:04 AM
#37
toxo I specified one of these for a job at a remote office recently. Set it up as a standalone access point, with the same name, security type, and passphrase as your current wifi network and job done! 2 yr manufacturer warranty too.
I could do with one of those my self, at the moment i have a second Wireless router extending my network but its not ideal, i only used it cos i had it available and new it was possible, but its fiddly at the best of times and the network is unstable too.
All i did was run a cat 5e from my UPC router to the second router and switched off DHCP on the second router and sorted out the ip addresses, and it works, but as i said already its not ideal, the network is very unstable and the setup is fiddly, so i may even look into one of thes range extenders...
ZAIS200
02-05-2021, 08:04 AM #37
02-05-2021, 08:11 AM
#38
Just to be clear, I wasn't suggesting to use that particular device as a range extender as that won't work in the OPs case. To function as an extender you have to have some overlap in the wireless coverage from the ISP router and the access point, which I don't think is the case here. It might work in your case, though.
The OP should use the device as a standalone access point due to the lack of overlap. All NAT & DHCP functionality will be taken care of by the ISP router.
02-05-2021, 08:11 AM #38
ZAIS200
02-05-2021, 08:34 AM
#39
yip i get you...
ZAIS200
02-05-2021, 08:34 AM #39
yip i get you...
Mikey
02-05-2021, 10:34 AM
#40
Cheers toxo for the link
just had a brain wave ive got a Linksys wrt54gs sitting at work i was just reading through this here do you think it will work as i just have it lying about (took it with a lot of stuff from a company who owed us money when they went bust).
if not it wont be a problem getting that one that you linked toxo
mike
Mikey
02-05-2021, 10:34 AM #40
mike
Views 510
14-06-2021, 06:10 PM
Replies 74
Views 9,704
19-09-2019, 07:24 AM
Last Post by johnyboy1976
Replies 23
Views 3,216
11-02-2019, 01:43 PM
Views 1,790
22-08-2018, 05:49 PM
Last Post by Chris
Views 2,407
01-07-2018, 01:25 PM
Views 626
05-06-2018, 06:46 AM
Replies 107
Views 9,625
30-03-2018, 06:28 PM
Last Post by John G
Replies 22
Views 2,418
23-03-2018, 07:43 PM
