ECU Tunning
ECU Tunning
Thanks for reply I'd rather be safe and get them if possible.
Last question on this will the pistons give noticeable bhp thus will end up being engine post if i carry on but want to know what to expect and then compare when map is being done
Lower compression will reduce your horsepower. You have to up your boost to compensate; the advantage of lower compression pistons is that you can run more boost with a lower likelihood of detonation. This is down to a safe map really, I'd be inclined to run slightly lower boost with a higher comp ratio and make damned sure it's mapped properly. The ~10:1 ratio of the IS200 is a bit high for ridiculous boost, but it is by no means impossible to turbo to high horsepower. Alpina get over 400hp on the N55 block with a 10.2:1 compression and fairly low boost.
Basically, simply dropping your compression ratio will reduce your power.
So low boost high compression or should I lower compression and up boost with bigger pulley
I've got a unichip for sale   only looking for £35 for it.
A member on here used to run a tte kit with a unichip fitted.
 But not sure what dyno result he had.
I will take it if I can get info on it as in is it as good as the ECU I was looking at?
Can anyone tell me if the uni chip will run the stage 2 injectors and pulley.
