JapCarForum Cars, Cars, Cars! Project Cars Supercharged IS200 race car
Pages (4): Previous 1 2 3 4
P.Lindblom
25-01-2020, 06:43 PM
#31
Sparkystav fantastic!will get myself a couple of lines made up.
what material did you use? im leaning towards copper nickel
I think I bought a copper pipe but copper nickel is a bit more durable. Under the car I'd go for copper nickel.
Also, I remember you asking if the car has a functioning ABS. It doesn't, it's electronically disabled as it does more harm than good on the ice.
P.Lindblom
25-01-2020, 06:43 PM #31
25-01-2020, 06:48 PM
#32
fair enough, well hopefully the roll lock shouldnt affect the abs. If not ill have to tie aswitch in with the roll lock switch to disable it when im using the roll lock
25-01-2020, 06:48 PM #32
P.Lindblom
25-01-2020, 06:50 PM
#33
Sparkystav fair enough, well hopefully the roll lock shouldnt affect the abs. If not ill have to tie aswitch in with the roll lock switch to disable it when im using the roll lock
I actually have no idea what a roll lock is, but it sounds interesting :tongue_smilie:
P.Lindblom
25-01-2020, 06:50 PM #33
25-01-2020, 07:30 PM
#34
Lock your front wheels up so you can do burnouts matey
25-01-2020, 07:30 PM #34
25-01-2020, 07:31 PM
#35
in short terms means you can lock the front wheels to do burn outs/warm rear tyres for 1/4 mile drag race...
25-01-2020, 07:31 PM #35
25-01-2020, 09:25 PM
#36
Yeah that's it, but also for loading as well pre drag.
Basically it's a solenoid, press the brakes. Press the button for the roll lock. Release the brake pedal but the roll lock locks the fluid in the front brake lines so they stay on, then you either light up the rear wheels, or user to start loading the clutch without rolling forward. Then release the button and it releases the fluid and away you go.
25-01-2020, 09:25 PM #36
26-01-2020, 08:16 AM
#37
Sparkystav Yeah that's it, but also for loading as well pre drag.
In a way, a form of launch control then?
26-01-2020, 08:16 AM #37
Views 15,633
Views 4,287
Views 184,867
Views 24,291
Views 50,404
Views 150,736
Views 1,427
Views 4,145
Views 7,150
Views 5,328
