Pages (76): Previous 1 … 38 39 40 41 42 … 76 Next
19-04-2018, 06:29 PM
Got the Focal components installed with the help of my housemate tonight after work. Made a massive but unsurprising difference over the broken Alpines Smile And they're not even amped yet as I have taken the amps and subs out to make way for camping gear! Pleased with that. Tomorrow is dizzy cap and rotor arm, then Wednesday I will try and do the coolant flush and thermostat. Car is still loads better following the oil change which is good. Smile Starting to look forward to Le Mans now!
19-04-2018, 06:29 PM #391
20-04-2018, 08:14 AM
The thermostat is a right ***** to get to on the MR2, its hard enough on the Lexus I had- good luck mate.
20-04-2018, 08:14 AM #392
20-04-2018, 08:16 AM
Well it's more accessible in the Rev3 than it is on your Rev2 due to the oil filter and cooler location, but also I don't have the intercooler in the way. There is 1 bolt that's a pain to get to though, that's true! We shall see Smile
20-04-2018, 08:16 AM #393
20-04-2018, 08:18 AM
The one right next to the aircon unit!! make sure your exhausts are cool otherwise its 3rd degree burn time:cursing:
20-04-2018, 08:18 AM #394
20-04-2018, 08:20 AM
Yeah Smile To be fair if the exhaust's not cooled then the coolant will be pretty hot too!
20-04-2018, 08:20 AM #395
20-04-2018, 09:57 AM
Doh!!
20-04-2018, 09:57 AM #396
Doh!!
21-04-2018, 07:27 AM
Did the rotor arm and dizzy cap last night. Boring as hell job but thought I'd write it up anyway!
Disconnect ECU-B and EFI fuses - ECU will need to learn new ignition advance from new ignition components.
Engine bay at start:
[Image: engineBayStep1.JPG]
Cross brace, dump valve, chargecooler overflow, PCV system removed, accelerator cable released, coolant float disconnected:
[Image: engineBayStep2.JPG]
Carbon cannister disconnected. Chargecooler off! The engine hanger you can see above the distributor is from a Celica not an MR2 - this gives the core something to mount to. This is about as far as I can move it without draining the coolant!
[Image: engineBayStep3.JPG]
Close up of offending item, held in with 1 bolt either side (right one is a bit inaccessible)
[Image: distributorCloseUp.JPG]
Dizzy cap off and resting on top of engine, best not to remove it completely as need to remember what order the leads go in :lol: Rotor arm exposed
[Image: rotorArm.JPG]
Rotor arm off, distributor gear completely exposed
[Image: distributor.JPG]
Shiny new parts to go on!
[Image: newparts.jpg]
New vs Old, rotor arm, screws and bolts. The rotor isn't actually that bad, but the black screws were mashed. I'd had to reuse them last time and they (like most Toyota fixings) are made of cheese. Replaced the lot, don't want to get into a situation like Hurricane did with his distributor:
[Image: oldPartsVsNewParts.jpg]
Inside old dizzy cap - you can see it's not *that* worn. It doesn't show up in the photo too well but there was some corrosion on the lower 2 contacts, presumably due to water and oil ingress. Pretty sure the seal had failed.
[Image: insideOldDizzyCap.JPG]
New dizzy cap to fit:
[Image: insideNewDizzyCap.JPG]
Reassembly is the reverse of removal :thumbup:
Edited 02-06-2010, 11:19 AM by toxo.
21-04-2018, 07:27 AM #397
21-04-2018, 07:32 AM
Sadly the work above has done nothing for my idle although the car does run smoother as would be expected. I have found yet more oil places it shouldn't be, and worse than that mayo in the catch can breather Sad Sad
There's nothing in the coolant, oil cap, either of the head breathers or the sparks so hopefully it's just water getting into the breather system rather than HG failure! Off to Pacific Works this evening where it will stay for the rest of the week, fingers crossed I will still be able to go to France.
21-04-2018, 07:32 AM #398
russelllinn
21-04-2018, 07:03 PM
fingers crossed it isn't the HG and you still get to France mate, nice write up too Smile
[Image: AliceTrack-1.jpg]
Have a look at my Scooby project thread here
My garage
Subaru
russelllinn
21-04-2018, 07:03 PM #399
My garage
Subaru
21-04-2018, 07:08 PM
Thanks. The thing that's playing on my mind at the moment is that rev3+ cars have such strong head gaskets that they will crack their blocks before the HG goes. Same symptoms though.
Should find out either tomorrow or Friday.
21-04-2018, 07:08 PM #400
Views 3,453
Views 3,973
Views 14,136
Views 6,908
Views 34,975
Replies 79
Views 11,228
02-09-2024, 04:19 PM
Views 5,156
Views 10,577
Views 1,628
Views 1,972
