JapCarForum General Discussions The JCF Lounge Av guys please come in here.
02-05-2021, 12:37 PM
#41
I have an extender I think. I ran a cat5 cable from my router to the kitchen door so I could get signal In the garage. But ive ended up with 2 networks. Can I fix this to one?
02-05-2021, 12:37 PM #41
02-05-2021, 12:49 PM
#42
Sparkystav I have an extender I think. I ran a cat5 cable from my router to the kitchen door so I could get signal In the garage. But ive ended up with 2 networks. Can I fix this to one?
Do they both have the same name and encryption settings? If they match, then client devices should just roam from one to the other. Quite often when doing this people mix up "WPA and WPA2", or "WEP and WPA", or "WPA or WPA2" which are all different settings.
02-05-2021, 12:49 PM #42
02-05-2021, 01:10 PM
#43
toxo Do they both have the same name and encryption settings? If they match, then client devices should just roam from one to the other. Quite often when doing this people mix up "WPA and WPA2", or "WEP and WPA", or "WPA or WPA2" which are all different settings.
No different names, both wpa2.
If I give them the same name will it just switch automatically to thestrongest?
02-05-2021, 01:10 PM #43
02-05-2021, 01:15 PM
#44
Sparkystav No different names, both wpa2.
In theory yes. The client driver has a value called 'Roaming Threshold' which some wifi cards let you change (so it will jump from one to the other more or less easily). If you go into the properties for the wireless card in device manager you can see if you have those options. It's entirely up to the client device as to whether it roams from 1 to the other, but that is how it's supposed to work. I would keep them on different channels, but make all other settings identical.
02-05-2021, 01:15 PM #44
02-05-2021, 01:18 PM
#45
Hmm I mainly use iPad and iPhone so prob can't play in the settings lol. Will name the, the same 'pretty fly for a wifi' and go from there lol
02-05-2021, 01:18 PM #45
02-05-2021, 01:20 PM
#46
There are some amusingly named networks around where I live. The one that sticks in my head is called "NI**A GET YOUR OWN WIFI". Mine's just called "Bob"!
02-05-2021, 01:20 PM #46
Mikey
02-05-2021, 04:15 PM
#47
have tried setting up the linksys wrt54gs with no luck so going to order the access point.
Mikey
02-05-2021, 04:15 PM #47
Mikey
13-05-2021, 10:29 AM
#48
Right o its working,
took my ps3 down the shed last night and got it working on the projector with internet (wired) so well chuffed about that,
ive orderd the TP Link wireless access point
10mtr hdmi cable
10mtr twin phono
hdmi splitter
also already have one of these Linky with a wireless keyboard and mouse so this will be connected through the splitter to the projector for general stuff so dont need to take the ps3 down there to browse the interwebs and stream stuff
next part is just tidying up all the wiring and sort out the speaker system for it
Mikey
13-05-2021, 10:29 AM #48
10mtr hdmi cable
10mtr twin phono
hdmi splitter
Mikey
13-05-2021, 10:42 AM
#49
Video of the android mini pc system would be good for car entertainment to i would think but the only think holding back is the video plays through the hdmi so need a connection in the car unless it can be switched to usb or simular
[youtube]JvKjdNs6wfU[/youtube]
Mikey
13-05-2021, 10:42 AM #49
13-05-2021, 11:53 AM
#50
You can't really play video over USB. It won't be long until we see double din head units with HDMI inputs though!
13-05-2021, 11:53 AM #50
Views 507
14-06-2021, 06:10 PM
Replies 74
Views 9,703
19-09-2019, 07:24 AM
Last Post by johnyboy1976
Replies 23
Views 3,216
11-02-2019, 01:43 PM
Views 1,776
22-08-2018, 05:49 PM
Last Post by Chris
Views 2,406
01-07-2018, 01:25 PM
Views 626
05-06-2018, 06:46 AM
Replies 107
Views 9,611
30-03-2018, 06:28 PM
Last Post by John G
Replies 22
Views 2,418
23-03-2018, 07:43 PM
