JapCarForum Trade Area Trade Archive Selling Archive Ultralite 18" alloys..
Pages (7): Previous 13 4 5 6 7 Next
02-02-2018, 06:08 PM
#41
yip thats what i've been telling people!!!!! but i like the euro look that the vw boys go for so i'd be stretching 215's on to a 9.5"wide wheel :thumbup:....not 1.5.........1.15"
my wheels i use on my car now run a et35 and poke out from the fender and they are only 8"wide......
02-02-2018, 06:08 PM #41
02-02-2018, 06:12 PM
#42
need some of these mate CLICK ME :w00t:
02-02-2018, 06:12 PM #42
TM
02-02-2018, 06:14 PM
#43
ormi yip thats what i've been telling people!!!!! but i like the euro look that the vw boys go for so i'd be stretching 215's on to a 9.5"wide wheel :thumbup:....not 1.5.........1.15"
then u would have a off set of 25mm....not good
the with of the rim won't afect it as it would be on the inside///wrong off set mate,
that a 25 off set
TM
02-02-2018, 06:14 PM #43
that a 25 off set
TM
02-02-2018, 06:34 PM
#44
Reverend HighTower then u would have a off set of 25mm....not good
that a 25 off set
Huhits even less mate
the only way the wheel stick out 1.5 inches,was if u had a 15 off set
check in the wheel and tyres thread for the off set guide
i have the IS250 with 35 off set on with a 9.5":thumbup:,the std wheel was a 45 off set
will take a few picture for u
TM
02-02-2018, 06:34 PM #44
that a 25 off set
02-02-2018, 06:50 PM
#45
i have the wheels on my car and the size is clearly visable.....as said when i first got these NO one thought they would fit due to the offset and width(that was over on loc before the ojc started)i cant run 225 tyres as the will hit the arch so i have to stretch 215's on.(their is also photos kicking about with how far my wheels poke out) you will see at knock hill...
bandit dont like over fenders i would just dial in some camber so they tuck under the arch......
02-02-2018, 06:50 PM #45
TM
02-02-2018, 06:55 PM
#46
ormi i have the wheels on my car and the size is clearly visable.....as said when i first got these NO one thought they would fit due to the offset and width(that was over on loc before the ojc started)i cant run 225 tyres as the will hit the arch so i have to stretch 215's on.(their is also photos kicking about with how far my wheels poke out) you will see at knock hill...
Blush
mate i have 275 /30 /19 on my motor,and have no rubbing problems,and they are a 35 off ste
turn the wheel on its head and measure the distance from the ground to the centre boss and post it up:thumbup:
TM
02-02-2018, 06:55 PM #46
Blush
02-02-2018, 07:02 PM
#47
here's the thing from the off set calculator
bandits wheels.
inner clearance 17mm less
outer position extend an extra 47mm
standard wheel stats......7" wide by et 50
new wheel stats............9.5"wide by et 35
and with my 8"wide by et35
inner clearance 2mm more
outer position extend an extra 28mm
Inner Clearance:
(the inside of the wheel to the strut housing)
Outer Position:
(position of the outside edge of the wheel)
calculator used
http://www.1010tires.com/WheelOffsetCalculator.asp
Edited 16-03-2010, 10:50 PM by ormi.
02-02-2018, 07:02 PM #47
bandits wheels.
Inner Clearance:
Outer Position:
calculator used
TM
02-02-2018, 07:05 PM
#48
Huhi'm not coming with the IS,I'LL be with the GS,but saying that i have the same off set on that,it just looks better
anyway we;ll see u at knocks hill:thumbup:
we will sort it for u mate,and get some fat rubber on your motor:thumbup:
TM
02-02-2018, 07:05 PM #48
02-02-2018, 07:06 PM
#49
ps mate your wheel arches are the size of my three bedroom house!!:lol:
i only have a baby is200..
02-02-2018, 07:06 PM #49
TM
02-02-2018, 07:12 PM
#50
ormi here's the thing from the off set calculator
bandits wheels.
Inner Clearance:
Outer Position:
calculator used
are these of the wheel that u have fitted
TM
02-02-2018, 07:12 PM #50
bandits wheels.
Inner Clearance:
Outer Position:
calculator used
Views 749
02-09-2021, 06:36 PM
Views 1,045
15-07-2021, 10:46 AM
Views 353
31-03-2021, 05:31 PM
Views 906
12-11-2020, 08:27 PM
Views 313
26-10-2020, 11:06 AM
Last Post by reco2k
Views 306
01-10-2020, 01:09 PM
Last Post by Bandit
