JapCarForum Car Manufacturers Lexus/Toyota IS200 / IS300 / SPORTCROSS / Altezza Project: DIY Supercharger
Pages (15): Previous 16 7 8 9 1015 Next
04-09-2020, 06:59 PM
#71
Been doing a bit of drawing work so I'm more prepared once the cradle arrives, got the outlet flange drawn up. Just need to print it out 1:1 so I can check I've definitely got it right, and then need to finish of the intake flange...
[Image: Flanges1.jpg]
EDIT: Just updated the drawing to have thicker lines as it was hard to see.
Edited 16-10-2012, 10:57 PM by sprinter2012.
04-09-2020, 06:59 PM #71
05-09-2020, 07:22 PM
#72
Spent a bit more time with the verniers and computer tonight, managed to draw up the exact positions of the mounting holes, none of which are square to anything on the charger, they are all just in random places. And also positioned the outlet drawing I already did in it's actual location relative to the cradle holes. I also added the ports inside the outlet just for refference too.
[Image: MountingLayout.jpg]
Edited 17-10-2012, 11:08 PM by sprinter2012.
05-09-2020, 07:22 PM #72
05-09-2020, 07:55 PM
#73
Looks good mate
05-09-2020, 07:55 PM #73
Looks good mate
reganlives
06-09-2020, 10:05 AM
#74
So once/if the cradles are made and if I got hold of a charger then what about the other bits that are needed? What about pipework etc? Would this need to be custom made?
reganlives
06-09-2020, 10:05 AM #74
06-09-2020, 11:09 AM
#75
So if I was looking on ebay , what merc charger should I be looking for , as in what car would need to be breaking so you would know that it was the correct one ??
06-09-2020, 11:09 AM #75
reganlives
06-09-2020, 11:21 AM
#76
The eaton m62 was normally used in the c180 kompressors IIRC.
reganlives
06-09-2020, 11:21 AM #76
reganlives
06-09-2020, 11:23 AM
#77
there you go, also on the CLK's apparently.
http://www.ebay.co.uk/itm/Compresor-EATO...2a243c7392
reganlives
06-09-2020, 11:23 AM #77
P.Lindblom
06-09-2020, 11:40 AM
#78
Moley So if I was looking on ebay , what merc charger should I be looking for , as in what car would need to be breaking so you would know that it was the correct one ??
From the top of my head, the Eaton M62 supercharger with the correct nose cone can be found in the following Mercedes models (pre -99)
C 200
C 230
CLK 200
CLK 230
SLK 200
SLK 230
P.Lindblom
06-09-2020, 11:40 AM #78
C 200
C 230
CLK 200
CLK 230
SLK 200
SLK 230
06-09-2020, 12:07 PM
#79
I was about to say the C180 has the stubby nose pulley version and is the incorrect size
06-09-2020, 12:07 PM #79
reganlives
06-09-2020, 12:27 PM
#80
Ahh so its only certain ones then that will fit? Which bit is the nose cone?
reganlives
06-09-2020, 12:27 PM #80
Views 796
29-08-2022, 03:48 PM
Views 1,127
29-08-2021, 12:58 PM
Views 359
27-12-2020, 08:44 PM
Last Post by Ste176
Replies 32
Views 2,808
07-09-2020, 04:37 PM
Last Post by sprinter2012
Views 581
31-08-2020, 08:38 AM
Views 1,817
19-08-2020, 05:50 PM
Last Post by Lance79
Views 1,227
04-08-2020, 06:31 PM
Last Post by mattlaw
Views 870
01-08-2020, 06:24 AM
Views 952
20-04-2020, 07:08 PM
Views 785
03-04-2020, 08:57 AM
Last Post by is300_dino
